Chain Question..WTF!
Old Apr 29, 2011 | 08:53 AM
newbierider77's Avatar
newbierider77 is on a distinguished road
so I adjusted the cain a bit today becaus it was way loose...Stiffened it up a bit and was good, have it on my stand. So I rolled the rear wheel a bit and the chain got loose again? Rolled it a little more and it got tight again?? Tight..loose..tight..loose.. Does this make any sence??
Old Apr 29, 2011 | 08:58 AM
Tight spots are an indication that you need a new chain.
Old Apr 29, 2011 | 08:59 AM
I had that once and there turned out to be a kink in the chain b/c of rust...
When you're turning it, watch the chain as it approaches the rear sprocket- you may notice the chain kick up as it goes over the sprocket. I ended up having to replace the chain...
Old Apr 29, 2011 | 09:01 AM
Dammit! Im getting a Schwin!! LOL
Old Apr 29, 2011 | 09:37 AM
Gauge cluster
Anyone have any Idea what this cluster is from?? Not a 98 Superhawk...But its what I've got on mine
Old Apr 29, 2011 | 09:47 AM
majordomo490's Avatar
majordomo490 is on a distinguished road
It's a later cluster 2001+
Old Apr 29, 2011 | 09:56 AM
But it is from a Superhawk??
Old Apr 29, 2011 | 11:42 AM
Yes
Old Apr 29, 2011 | 01:02 PM
FLETCH's Avatar
FLETCH is on a distinguished road
REPLACE THE CHAIN AND THE SPROCKETS AT THE SAME TIME-STRETCHED CHAIN WILL HAVE WORN YOUR SPROCKETS. INSTALLING NEW CHAIN WITH YOUR WORN SPROCKETS WILL WEAR NEW CHAIN AND WORN SPROCKETS EVEN FASTER.
Old Apr 29, 2011 | 05:16 PM
mboe794's Avatar
I had the same problem with the chain being tight in one spot but loose in another. I drove myself nuts for a while trying to find the cause. Turned out to be a missing roller. I even found one half of it jammed in the crud that builds up behind the front sprocket cover.
bluevtr
Mar 5, 2009 06:54 AM
superchickencornermonster
Dec 30, 2007 11:08 PM
j_frank
Sep 25, 2007 08:40 PM
nineighthawk
May 25, 2006 09:51 AM
SlowHAWK
Aug 19, 2004 01:07 AM
