cct question
Old Oct 13, 2009 | 06:11 PM
uchi's Avatar
cct question
ok i know this has been beaten to death on here. im getting ready to do mine and just want to make sure ive got the right idea here. put the bike on the stand, 6th gear, remove timing mark cover, line up the rt mark with the timing marks, and from there i can either remove the cam cover or just remove the cct carefully and if i dont hear a click im fine, and for the front i line up the timing marks with ft and repeat the above steps. and if i wanna be safe i can remove the cam cover and line up the marks and then ziptie the chain to the cam gear first before removing the cct. does that sound about right? just wanna be 100% sure ive got this thing figured out before i do this.
Old Oct 13, 2009 | 07:12 PM
uchi's Avatar
Also should I buy the apes or make my autos into manuals?
Old Oct 13, 2009 | 07:34 PM
I have a semi coherent walk through linked in my signature (PDF format) feel free to print that out.
You really should remove at least one of the valve covers (rear is easier) because the timing mark lines up twice in the 4 stroke rotation and in one of those TDC situations there is still a little pressure on the valves risking a timing chain jump.
As for self made manuals vs APEs.. if you do a good job making them, there is no real difference. If you mess up making them, then that's on you... For the $110 for a pair, I went ahead and purchased APEs.
Old Oct 13, 2009 | 07:59 PM
Oh, another note.. we printed out walk throughs from several sites (this one, the UK forum, etc) and used all that info and made sure each step made sense as we did it..
I would recommend doing the same.. If you run into something that isn't covered in one person's walk through, read the others to see if they say something about it. (I know my walk through isn't perfect either lol)
Old Oct 13, 2009 | 08:14 PM
Little_Horse's Avatar
2nd mouse gets the cheese
easiest method I know is to take the rear valve cover off make, line up the rt mark, the cams should point down and away from each other (there is a picture on the sticky), but not be pushing on the valve. Remove the cct slowly replace with the manual one. Next rotate the engine 450 degrees the direction your bike normally runs until the ft mark lines up. Then slowly remove the front cct and replace. Put the rear cover back on and be off. Also the 450 degrees part is burried in the sticky somewhere too it may be wise to double check my numbers. I have done this job a couple of times and this made the job pretty easy.
Old Oct 13, 2009 | 08:23 PM
uchi's Avatar
Sounds good. Thanks for all the info guys. I think I may just buy some manual ccts just to have them and not have to bother making some.
Crashrat
Oct 11, 2012 08:25 PM
Verne
Oct 3, 2007 03:23 AM
altosuperhawk
Jun 19, 2006 08:17 PM
SlowHAWK
Jun 9, 2006 09:38 AM
mikenap
Jun 7, 2006 07:01 PM
