Carburettor Boots
Old Jul 3, 2008 | 12:55 PM
Gerrit's Avatar
Gerrit is an unknown quantity at this point
Carburettor Boots
Having battled with the erratic idling, and unsuccessfull carb sync, I tried something different tonite.
With the bike idling, I sprayed "Quick-Start", onto the rubber mounting boots of the carbs...Almost instantly the idling changed, slowed and the engine stalled.
So I assume one can conclude from this, that the boots are leaking?
Question is do these boots "seat" less well, after a few removals of the carbs, or pehaps develop "leaks" over time?
I don't wanna spend the money on new boots if there is a better solution.
Regards,
Gerrit
Old Jul 3, 2008 | 01:04 PM
hawxter996's Avatar
ole dirty bastard
they seem to harden and not seal as well.
try playing with them a bit,maybe just not seated correctly.
Old Jul 10, 2008 | 08:42 AM
speedhawk's Avatar
One Wheel Wonder
speedhawk is on a distinguished road
I had to replace my carb boots too. i sprayed carb cleaner on them and the and it changed on me too. i replaced the boots, sprayed it again, and the idle STILL changed. i re-checked and then even checked AGAIN that i installed them well.. perfect every time. but the idle still changed when i sprayed carb cleaner on them. my theory to this day is that when you spray them, the mist and vapor gets sucked in through the air box. i could be wrong... but there is NO way my boots are leaking. i also put a thing layer of grease on the inside of my boots for ease of installation and a better seal.
i am not telling you NOT to replace them, cause my old ones were hard too. but just letting you know how they reacted to the carb cleaner.
Old Jul 10, 2008 | 10:25 AM
codfish124's Avatar
SuperCock roster
codfish124 is an unknown quantity at this point
use propain it sinks and you can really get a feel for where its leaking (the idel will pick up with a leak)
Hawk9807
Jun 16, 2008 05:04 PM
dantropolis
Jul 10, 2007 02:14 PM
F1 Fan in Nascar Land
Nov 29, 2006 10:34 AM
nophr
Sep 17, 2006 07:25 AM
nnjhawk02
Mar 29, 2006 06:47 AM
