Carb synch backwards?
Old Jun 10, 2010 | 03:46 PM
dshakes's Avatar
dshakes is on a distinguished road
When you are synching the carbs and you open the throttle shouldnt the oil in the tubes rise? Like it will be sucked into the engine? Once i have the tubes on and the bike running if i open the throttle or even blip it hard the oil in the tube goes down toward the floor. Like the motor is pushing air out instead of a vacuum in. Do i just need a lesson in physics or is something wrong?
Old Jun 10, 2010 | 03:53 PM
There is more vacuum at idle than at full throttle. I forget the exact physics of it, but manifold vacuum decreases as RPMs increase.
Old Jun 10, 2010 | 04:00 PM
peterpanic's Avatar
pragmatic anarchist
yeah, like how my old schoolbus vac wipers went real fast at slow speeds and then slowed down to a stop as the nut drove through the downpour WAYYYY too damn fast!
Old Jun 10, 2010 | 05:07 PM
alwayshonda's Avatar
alwayshonda is on a distinguished road
It's like sucking on a straw with your finger over the opposite end. Your finger is the throttle plate, the straw the intake manifold, and you are the draw from the pistons. The more you remove your finger, the easier it is to draw in air, and the lower the vacuum is within the straw.
Old Jun 11, 2010 | 02:47 AM
dshakes's Avatar
Gotcha.
uchi
Sep 14, 2010 08:07 AM
viperkillertt
Sep 23, 2008 07:37 PM
smack doogle
Jul 29, 2008 08:18 AM
Shawn Torpey
Feb 12, 2007 04:31 PM
shayne
Aug 1, 2006 02:15 PM
