carb sync question
Old Feb 1, 2010 | 04:01 PM
pwolski's Avatar
pwolski is on a distinguished road
carb sync question
So I just did the needle shim .020, TPS (the top and middle pin at 500) and removed PAIR. I also installed vacume pick up for the front cyl and Tee into rear by the fuel valve. I made my yard stick and ATF symc gauge and was very excited about smooth running hawk.
I also found K&N filter with misssing plugs and the small foam filters for the diaphragms. Plugs are on the way, but I am flying out to the island in a day so I attempted to sync carbs with the airbox open. The bike runs not so well. I do need the back pressure created by the airfilter/snorkel for the carbs to act right?
To close the airbox I would need the plugs for the diaphragms (to isolate any vacum created on the carb side of the air filter, which I don't have. I will make the foam filters that are missing from air filter foam.
Is my thinking correct on this one? Thanks.
Old Feb 1, 2010 | 04:16 PM
Yes you do need to have the airbox fully assembled in order for the bike to run right so you can sync the carbs.
uchi
May 8, 2011 08:13 AM
superh1998
Jul 10, 2010 02:54 PM
nath981
May 3, 2010 09:30 AM
dondiggdy
Jul 27, 2009 11:44 AM
dickard37
Feb 1, 2009 08:14 PM
