carb problem...pls help!
Old Mar 19, 2010 | 11:46 PM
draqqora's Avatar
personal memory disabled
draqqora is on a distinguished road
hi, i have a big problem on vtr 1000f 1997, the motor does not idle smooth, when i try to accelerate it stops, and the sparkplugs turns to to black in the rear cylinder and in the front one it turns to white....i tried to sync the carbs and changed allready the plugs but it feels the same...i even measured the intake and exhaust clearance and they are good.......what sould i do next?....
Old Mar 20, 2010 | 12:17 AM
residentg's Avatar
are you getting a spark in the rear cylinder? JB
Old Mar 20, 2010 | 12:21 AM
draqqora's Avatar
yes, sparks good,...both cylinders.....even checked them with the colortune and it seems ok.....thx for askin'
Old Mar 20, 2010 | 12:30 AM
draqqora's Avatar
forgot to tell: i mounted hiflow exhaust REMUS pipes and also put K&N air filter.....maybe rejeting the carbs will solve the problems?
Old Mar 20, 2010 | 03:00 AM
residentg's Avatar
when the engine has warmed up, splash a few drops of water on the front and rear header pipes. See what happens, look for the difference betwen the two.
How does the engine run past idle? JB
Old Mar 20, 2010 | 03:11 AM
draqqora's Avatar
the engine runs poor untill 3000rpm(when i can start it!), i cant get it over 3k....and i think the front cylinder runs more colder than the second one......f**k...so nice weather and i aint got no bike.....
Old Mar 20, 2010 | 05:03 AM
Stevebis1's Avatar
What lead up to this? I assume it ran ok and then it stopped? Or is this a situation that the bike was put away and then when you got it out this is what you found?
What lead up to this is important - it will give us better ideas on where to start.
Old Mar 20, 2010 | 05:56 AM
draqqora's Avatar
....it was away for like 4 months, during the winter....., and after i cleaned the airfilter, changed the plugs, oil and oil filter and put a new baterry, the motor got running from bad to worse , and now ......it's in braindeath....and i'm already exasperated........thx for tryin' helpin'me mate....
Old Mar 20, 2010 | 07:01 AM
residentg's Avatar
for diagnostic puorposes only, take out the air filter, and see if the bike runs. If it is better, you need to clean or replace the filter. If still bad, put back in the old plugs and see how it runs...
let us know
Old Mar 20, 2010 | 07:28 AM
zmaniv's Avatar
Sounds to me like the bike may be jetted wrong.
Front plugs white rear black.
Old Mar 20, 2010 | 11:31 AM
Also sounds like a big vacuum leak on the front cyl. but might even be the petcock vacuum line. So hard to trouble shoot on line..... and I personally hate those K&N filters...... took mine out and gave the POS away....
Old Mar 21, 2010 | 05:13 AM
Stevebis1's Avatar
+1 I agree that it may be jetted wrong, but it need to be running first. A jet problem generally does not get worse so I would look for a vacuum leak also. Spark & Fuel. If you ae sure the spark is there then it has to be fuel...
Old Mar 21, 2010 | 11:51 AM
glock221's Avatar
glock221 is on a distinguished road
Did you just add the pipes and filter or have they been on there? If you just added them, I would say jetting.
Old Mar 22, 2010 | 02:17 PM
draqqora's Avatar
hi again.....i got it!!!....after dismounting and cleaning the carb, checked again the valves, the vacuum and all the other stuff I finally got it.....the hose which goes to the fuel valve under the tank had a small crack in it, and from there all the trouble.....false air firing and normally , not enough fuel for my hungry beast ........such a small thing and such a big headache .......some times we can not see the tree in front of us because we have a forest in our eyes....any way, thanks u guys for all the help.....
Old Mar 23, 2010 | 04:32 AM
BeerHunter's Avatar
Slacker
It is always a big relief to find that the problem is something so easy to fix! I changed the vacuum line a couple years back since it was becoming hard and showing signs of imminent failure (cracking). Sometimes a temporary fix with vacuum/fuel lines can be done by cutting off the end which has permanently expanded, if there is enough length left to work with.
bostonhawk
Sep 1, 2012 08:45 AM
Red_Liner740
Jul 25, 2009 03:30 AM
kraher
Apr 21, 2009 09:39 PM
VTRDenmark
Apr 21, 2009 10:40 AM
vasaq
Aug 24, 2007 01:27 PM
