cam gear timing marks
Old Aug 14, 2012 | 08:04 PM
99superhawk_Dom's Avatar
99superhawk_Dom is on a distinguished road
i was ridding at 60mph when the engine started knocking and died when i pulled in the clutch. i turned it over when i got it home to see where the noise is comming from and it fired but died. the knocking seems to be coming from the front. so i pulled the valve cover and spark plug. the front cylinder is moving up and down so the next thing i want to do is make sure it didn't jump time but can't find where the marks on the gears should line up. please help.
Old Aug 14, 2012 | 09:37 PM
So i figured it out it was not the cct on the front cylinder it is the one on the rear.
Old Aug 15, 2012 | 07:38 AM
98VTRrider's Avatar
So it was a rear CCT failure? Did you go through the steps to check valve timing on the front and rear?
Old Aug 15, 2012 | 11:22 AM
yes i checked the front and the marks look correct. when i was turning the motor over manually to line up the rear i noticed the cam chain slipping, and one of the exhaust valve risers is not coming up all the way so there is at least one bent exhaust valve. will know more after i get the head off.
I'm going to replace both of the ccts (OEM replacements are $83) any suggestions on which ones are the best.
Old Aug 15, 2012 | 12:30 PM
merckid's Avatar
merckid is on a distinguished road
something like this is your best bet
2 Manual Cam Chain Tensioner Honda VTR 1000 Super Hawk | eBay
Old Aug 15, 2012 | 12:37 PM
Or contact this list member: SuperHawk Forum - View Profile: superdutyd
Old Aug 18, 2012 | 01:50 PM
GTS's Avatar
GTS
Seasoned tech
Go for manuals. I got mine from Superdutyd and am really happy with them. Make sure to look at the guides when you take the valves out as well. When mine went (both intake valves on front cylinder) both guides were cracked as well.
Old Aug 19, 2012 | 04:42 PM
4 bent valves, piston is fine and the valve seats look fine.
Thanks for the help.
Old Aug 19, 2012 | 07:11 PM
GTS's Avatar
GTS
Seasoned tech
Ugh that sucks! How do the guides look? Mine had three cracks in each one with the bent valves.
whatthefnck
Apr 14, 2017 10:15 AM
Mchurch
Jul 22, 2013 02:33 PM
JamesK
Apr 11, 2009 07:00 PM
Kendrick
Nov 17, 2008 02:42 AM
cliby
Mar 1, 2007 09:55 AM
