Broken cam cover bolt
Old Aug 24, 2009 | 11:29 PM
rtinti's Avatar
rtinti is on a distinguished road
i overtightened one of my cam cover bolts and snapped it. I blame it on accidentally dipping the bolt in oil just before lining it up and tightening it down, but I'm not feelin' too bright. didn't take much to break it.
guess I'll hit the hardware store tomorrow to buy an EZ out bit, and hit the dealer to order a new bolt.
dammit.
At least my APEs are in without needing to retime the bike, and the bolt went before stripping out the case.
Old Aug 25, 2009 | 04:13 AM
Buy yourself a left hand drill. Same size as what you need for the broke bolt extractor. Chances are, the broken bolt will come out as your drilling the hole.. If not, then you needed the hole anyway for the extractor.
Old Aug 25, 2009 | 06:26 AM
comedo's Avatar
+1 EZ outs are really brittle. If you said a bad word when the bolt snapped, you'll say a hundred if the EZ out breaks. BTDT
Old Aug 25, 2009 | 06:37 AM
I should have added.. Before you do anything else.. remove the cover, uses a sharp pick and see if you can back out the remaining part of the bolt. If it simply sheared by too much tension, and not cross threaded or bottomed out in the hole,, Now that the tension is off, it may just rotate on out. After that,, try the left hand drill bit...
Old Aug 25, 2009 | 07:44 AM
fuzzuki's Avatar
fuzzuki is on a distinguished road
Yeah, remove the entire cam cover. Then use vise grips on the bit still sticking out.
Old Aug 25, 2009 | 07:49 AM
Sears sells screw/bolt outs that I've used with great results. The tip is like a drill and then it's threaded and it works really well for extracting broken off or stripped bolts and screws.
Old Aug 25, 2009 | 07:51 AM
Oh and Lisle also sells an extractor set that has worked great for stuff like broken header bolts in cylinder heads, etc.
Old Aug 25, 2009 | 08:14 AM
motojoe's Avatar
Sexual Daredevil
A trick I learned is there is not too much torque on the bolt is to use a spring loaded center punch. Push on it with your hand. (DO NOT USE A HAMMER!) That may loosen it until you can get a better grip on it.
Old Aug 28, 2009 | 09:11 PM
rtinti's Avatar
i figured I needed an easy out bit set so just bought it. I had to drill 2 pilot holes, 1 with a 1/16th and then 1 with a 3/32 to get the EZ out bit in. that worked, but now I wish I would have just bought left hand drill bits.
the bolt broke off under the surface so vice grips wouldn't work. it's out. a new bolt was $9 but everything is back together and running great so I'm content.
Old Aug 29, 2009 | 06:31 AM
chickenstrip's Avatar
chickenstrip
Funny how those bolts cost $$. I think about replacing all of 'em when doing valve adjustments - to get nice clean heads and to avoid breakage from fatigue - but at $9 a pop it's not like just getting some bolts, if you know what I mean.
Old Aug 29, 2009 | 08:48 AM
steve.g's Avatar
Whenever I bolt covers on a bike engine I put a little anti-seize compound on the bolt threads.This really seems to help when I remove the bolts next time.Haven't broken one in a long time. Glad you got the busted bolt removed without to much hassle.
mikstr
Sep 18, 2012 09:37 AM
salmanilla2000
May 9, 2011 12:05 PM
salmanilla2000
Apr 27, 2011 10:41 AM
Jaymidd
Mar 11, 2010 02:13 PM
L8RGYZ
Sep 26, 2006 07:13 AM
