BROKE TPS AS USUAL... DOES IT REALLY DO ANYTHING
Old Apr 7, 2009 | 01:31 PM
skoshere's Avatar
I broke my TPS as many on the forum members have... After reading centralcoaster and others posts, i gather the TPS doesnt do much... (besides detonation at higher RPM's???? and be really easy to break)
Is this true, as it is expensive from Honda
Old Apr 7, 2009 | 05:20 PM
JamieDaugherty's Avatar
I don't know, my experiences and those of others suggest that it's pretty darn important. The ECU uses a 3D ignition advance map in it's programming. What that means is that it varies the ignition timing based on engine rpm and also throttle opening. If your TPS is not working or not set correctly it will throw the map onto a curve that is not correct. The engine will still run, but expect less performance and some rough running.
Old Apr 7, 2009 | 05:26 PM
996SSVTR's Avatar
Nose Picker
996SSVTR is on a distinguished road
I second what Jamie has said, a friend of mine a Harley machanic said that alot of the problems I was having was because of my TPS not being hooked up.
Old Apr 7, 2009 | 05:59 PM
skoshere's Avatar
i figure if Honda engineers put it there, it had to have a purpose.
I was able to slightly drill a hole on the twist part to get a good mounting surface to try to repair it. It seems to be alot stronger than original... hoping once it dries and test the reistance on it
Old Apr 7, 2009 | 08:17 PM
How do you know if your TPS is broken?
Old Apr 7, 2009 | 10:11 PM
Measure with an ohmmeter. Resistance should change linearly as the throttle is opened slowly and then go the opposite direction back to where it started when closed.
Old Apr 9, 2009 | 08:21 AM
So how would you know its broken? Only by measuring resistance? Where is the measurement taken?
Old Apr 9, 2009 | 08:49 AM
Pages 17-8 and 17-9 in the Honda factory manual describes the complete procedure for testing the TPS.
Quick test is: (key off)
1. unplug TPS connector on right side of rear carb.
2. TPS has 3 pins, one is usually 5V reference voltage, one is signal voltage and one is ground.
3. put ohmmeter leads on signal and ground terminals (it looks like they are the outside terminals).
4. as throttle is opened slowly the resistance should decrease gradually, then return to where it started when throttle is closed.
On a car I would use a voltmeter or lab scope to check the circuit live by backprobing. That is a more accurate test, but Honda says test with ohmmeter.
Old Apr 9, 2009 | 09:03 AM
skoshere's Avatar
i know its broken because it fell apart... I think I may have fixed it though
8541Hawk
Aug 27, 2011 01:20 PM
ProfChaos
Aug 5, 2011 03:57 PM
uchi
Dec 28, 2010 05:57 PM
JoeSnowden
Mar 20, 2009 09:07 AM
johnnyhonda
Jun 29, 2007 05:02 AM
