blinker problems
Old Feb 11, 2011 | 11:19 PM
Ryder3610's Avatar
Ryder3610 is on a distinguished road
blinker problems
Back before winter actually hit I started having problems with my blinkers when the temp started dropping, I was riding it in about 40 degrees when it first started. I would turn the blinked on to turn and wouldnt come on but a couple minutes later it would be on and it got to where it won't come on. Is it the temp change, a short or the relay ?
Old Feb 12, 2011 | 02:08 AM
Well... This is something you would find an answer to using search as it's been discussed a couple of times...
To start you off though, it's likely to be the grease in the switch being old and filled with dirt/moisture... Disassemble and clean it, and give it a liberal gob of vaseline... For more details, https://www.superhawkforum.com/forums/search.php
Old Feb 12, 2011 | 12:28 PM
Ryder3610's Avatar
Thanks man
Old Feb 12, 2011 | 12:45 PM
Kendrick's Avatar
The Hypno-Toad
Just fired up mine today. It's 32 degrees in Wisconsin! Yeah mine don't work below 40 F. It's just a Superhawk thing.
Old Feb 12, 2011 | 01:01 PM
j shizzy wizzy's Avatar
mildly retarded
Hey tweety, you think Vaseline is better to use than Dielectric grease? I was thinking about getting a tube and going through my connections a lil' bit at a time over the course of this summer...
Old Feb 12, 2011 | 05:30 PM
Go with dielectric grease, save the vaseline for....something else
Old Feb 12, 2011 | 06:34 PM
98VTRrider's Avatar
I had the same problem today...first ride in sub 40 degree weather...seemed like the left signal would come one sooner than the right, for whatever reason....but both were delayed a few seconds at the least
Old Feb 12, 2011 | 09:05 PM
The dis-assemble and grease can help. A new switch unit also helps. It isn't the most long living piece on the hawk.
Old Feb 13, 2011 | 07:00 PM
wshski's Avatar
wshski is on a distinguished road
Yep, mine did it yesterday also in the 40's. Must be a cold thing.
Old Feb 13, 2011 | 07:52 PM
You should try them in the teens. It helps to move the wires coming out of the switch
Gtogie
Aug 14, 2011 12:58 PM
joshuatest
Apr 13, 2008 10:12 PM
killer5280
Oct 27, 2007 09:34 AM
VTRBandit
Jun 9, 2007 12:26 PM
bockspa
Aug 21, 2006 08:17 AM
