Beginning jet settings incorrect...2nd times a charm
Old Aug 4, 2005 | 03:32 PM
99Hawkboy's Avatar
99Hawkboy
ok..I rejetted my bike the other day with the following settings from the factory jet kit.
#175fr/#178r
needles at 2nd clip
2.5 turns on fuel screw
#50 pilot jets
when i used these settings when the bike was cold, and cruising from 3-4000 rpms the engine would missfire slightly. When the engine was warmed up cruising from 2-5000rpms the engine would missfire a lot.
at idle revving the engine developed no backfires and it sounded wicked.
the upper rpm band was powerfull cold and hot.
So i figure that the engine is still lean because of the missfireing.
Im thinking about these settings....
#178fr/#180r
additional 1/2 turn on fuel screws
2 clips on needles
#50 pilot jet
What do you guys think?
Old Aug 5, 2005 | 12:10 PM
99Hawkboy's Avatar
99Hawkboy
Re: Beginning jet settings incorrect...2nd times a charm
Ok. I have some good and really messed up news.
Today I re-tuned my jet process on my bike and changed the settings on my needle clips from 2-3 and adjusted my fuel screws back to there original position which was 2 3/4 on the front and 3 on the rear. Hopefully this will make the midrange a little bit richer. At least i think it is running lean because it keeps missfiring in the midrange.
In the instructions it says if the engine has a "dry" flat spot at aproximately 3500 to 4000 rpm, raise the needle from 2-3. This will richen up the area.
And if the enigine has a "wet" rythmic, soggy spot at 4000 rpm that getts worse as the engine heats up lower the needle and lean out that area.
But what if my symptoms are both. I cant really tell because it just missfires.
When the engine was at idle the bike missfired a couple of times up untill i shut her down.
So my current settings are:
#175fr/#180R
needle at 3rd clip
2 3/4 turns on fuel screw front and 3 turns out on rear.
#50 pilot jet
This time it only took about an hour to do all the work on my bike but when I went to put the carbs back in the bike I STUPIDLY overtightened the front choke cable and it broke off in the carb.
So after a little bit of work I got the broken piece out of the carb and the 2nd broken piece out of my cylinder hole! Thank god the intake valve was closed and I ordered up a couple of new cables from honda.
So next week I will get to test out my settings. Damnit! I really wanted to go cruising tonight.
Old Aug 10, 2005 | 01:32 PM
99Hawkboy's Avatar
99Hawkboy
Well I am still waiting on the choke cables to get in! Damn Honda. They were on backorder which I didnt learn from the delears untill yesterday. Freaking bitch! But I ordered the part on Bikebandit.com and paid extra for the shipping out here. So maybe Saturday I will get the part in. Untill then Im just twiddling my thumbs.
Old Aug 15, 2005 | 05:37 PM
99Hawkboy's Avatar
99Hawkboy
Finally!!
I got the valve for the choke cables in today and put my carbs back in and took it for a ride. Man! No missfiring, pulled wicked! and is smooth idling. I may have to raise the idle a bit because it is below 1K but it is sweet to finally be able to ride my bike and nothing bad happen :P
Final settings:
#175fr/#178R
needle at 3rd clip
#50 pilot jet
These settings are with. K&N air filter, Exhaust Bafflectomy, PAIR disabled, Air box screen on left side removed.
Bike runs great and runs pretty cool. About midway on the temp gauge.
Old Aug 23, 2005 | 10:44 AM
102dals's Avatar
Any of you guys have a PDF, or other Doc style file, of the DynoJet instructions? My VTR had a kit when I bought it (used /w 2000mi). I have leftover jets, but no instructions! It runs well, with Yosh Ti slip-ons and a K&N, but if I want to make changes I have no idea which way to go?
Thanks, even a Factory set of instructions would help.
Old Aug 23, 2005 | 01:05 PM
AZZKIKER's Avatar
If it runs well, don't mess with it.
Old Aug 23, 2005 | 06:42 PM
99Hawkboy's Avatar
99Hawkboy
First...I dont have my scanner so I cant scan the Factory instructions in for you 102dals
Secondly back to my jetting...
I was wrong in my assumption that I had it all figured out. I dont yet. At idle the engine sometimes just dies. Why does it do this? Is it too lean, to rich? Whats it doing. Do I need to adjust the fuel screws?
thanks
Justin
Old Aug 26, 2005 | 02:31 PM
102dals's Avatar
It isn't that I want to mess with it... I just want to know what they are, and what they should be.
I've changed jets a million times on my 88 Hawk GT, and I know it's the same procedure. The carbs even look the same.
Anybody?
Old Aug 30, 2005 | 10:09 AM
Tampa_Harrier's Avatar
Tampa_Harrier
When I had the Factory #50s in it, I couldn't make it idle reliably with any jets/clip/screw settings. Had to fall back to the #45s.
On the plus side, if anyone in Florida needs their carbs pulled, I've gotten quite profficient at it...
MILKMAN65
Apr 14, 2010 09:17 AM
scottiemann
Mar 3, 2007 07:48 AM
kevink2
Feb 2, 2007 03:25 PM
sprhawk neil
Forum Feedback
Jul 29, 2006 08:36 PM
99Hawkboy
Jul 31, 2005 12:47 PM
