Backfire shaking
Old Oct 10, 2016 | 11:08 PM
Jborty's Avatar
Jborty is on a distinguished road
Smile Backfire shaking
Ok all time for a little help....
I am new so please try to be helpful. Thanks
When riding at approx 45 -60 mph I get this noticeable what seems to be a sputter or backfire sound and the bike shakes a little in a few seconds it goes back to normal and acceleration is fine. Rpms are at 30,000.
Problem #2 when squeezing the clutch to use engine breaking the Honda has shut off on me. It fires right back up but has happened several times.
This bike has had a jet kit put in and recently a new motor. Any thoughts to problems? Maybe airbox, maybe petcock my mech has had the bike in and out of the shop all month working on it.... Thank you all
Old Oct 11, 2016 | 06:25 AM
There's your problems.
OK so I know you meant 3K. Engine must be missing in that RPM range. May due to the jet kit. Have you looked at the plugs? Does it have a K&N filter?
I don't understand the clutch pulled for engine braking. Do you mean engine quits while hard braking with the clutch pulled in?
Old Oct 11, 2016 | 04:44 PM
Jack Flash's Avatar
Well take off, eh.
Jet kit is definitely your culprit, but you will have to provide more info on that to guide you and be sure.
If engine shuts off while pulling the clutch, is another symptom of faulty carbs. Once again, find out what was put in, and the carbs will certainly need a good syncing since the carbs have played with plenty.
I also recommend visiting the knowledge base of this forum, there is plenty of info concerning your issue. Enough for you to read till your eyes bleed.
brickbats
Aug 14, 2008 08:50 PM
mlshuford
Aug 10, 2007 08:36 AM
LeanRider
May 17, 2007 02:31 AM
SuperHawkins
Jan 29, 2007 04:54 AM
MisterMohawk
Apr 28, 2006 07:34 AM
