Another chain thread.
Old Jun 4, 2011 | 09:22 AM
geekonamotorcycle's Avatar
Today I finally got all my parts together for a much needed swap
I am going to stock gearing and have a few questions. I was told that 120 links is the proper amount of links, but the manual says 102.
This is a 525 pitch chain.
Should I cut this chain down? What is the proper way to count and cut links?
I have a stockton Kit
Cycle Gear - STOCKTON TOOL COMPANY: Chain Breaker and Rivet Tool Kit,
and no real idea how it works.
How do I rivet the master link on this change?
Old Jun 4, 2011 | 09:58 AM
saige's Avatar
the boss
102 links is correct,dont go any less.
each rivet is a link.the chain has to total 102 links when conected together.
becarefull when cutting.
the kit should have instructions,i hope anyway.
that kit is 30.00,was gonna get one.
the pin has to be pushed thru with the tool,and than pinched.all the parts you need will be in the kit.
Old Jun 4, 2011 | 10:00 AM
saige's Avatar
the boss
play around with old chain first to learn how to take out the rivets,plus anyway,you gotta take off old chain.once you do that,you will get idea how it works.
ok so I need to count 102 individual pins? Saige you wanna come over and supervise lol?
Old Jun 4, 2011 | 10:01 AM
I have a brake/clutch bleeder so we could flush out your system while we r at it.
Old Jun 4, 2011 | 10:03 AM
Ahh I see
YouTube - ‪How To Buy a Motorcycle Chain‬‏
Old Jun 4, 2011 | 10:04 AM
saige's Avatar
the boss
yea,im off today,i got nothing to do,i will be over.txt me the road you live on.i know how to get there as long as i know the road to turn on.
Old Jun 4, 2011 | 10:07 AM
Bring some dot 4 fluid if you wanna flush your system!
Old Jun 4, 2011 | 10:20 AM
Personally I never count pins. Just install the new sprockets then put the chain on and put one end on the top of the rear sprocket and wrap the other end up and around the sprocket and it becomes quite obvious where you need to cut.
Check twice, cut once and then rivet them together on the rear sprocket (it's much easier than trying somewhere in the middle of the run)
I also use my vernier calipers to make sure the new link has the same inside dimension as the factory links before I rivet it together.
Also make sure you clean off all the shipping grease (mineral spirits work very well for this) before you install the chain.
Old Jun 4, 2011 | 10:29 AM
8541 That was my backup plan lol.
Old Jun 4, 2011 | 01:38 PM
Ok we are having trouble finding the torque spec for the front sprocket. Does anybody know where this is even printed in the manual? We think it might be 65 ftlb? My haines manual does not seem to have it listed either.
Old Jun 4, 2011 | 01:52 PM
40 ft-lbs page 7-2 of the factory service manual
Old Jun 4, 2011 | 05:20 PM
Thanks again 8541. We found it right after I posted the question in the haynes manual.
NHSH
Nov 12, 2013 09:36 PM
Slim
Dec 12, 2007 09:22 PM
midijunky
Nov 10, 2007 11:07 PM
Fish
Oct 13, 2007 01:56 PM
3D02
May 23, 2006 08:04 AM
