AIRFILTER HELP
Old Dec 9, 2008 | 11:54 AM
ericb269's Avatar
kneeedragger
ericb269 is on a distinguished road
AIRFILTER HELP
I have a 99 SH and I was serviceing it and found that the stock filter was real dirty so I opted to buy a k&n filter. The filter comes with 2 rubber block off pieces which seems to block the cranck case breathers. well the bike seems to have more power but just off throttle it will backfire threw the carbs any suggestions.
Old Dec 9, 2008 | 12:02 PM
if you use a K&N on the SH you have to rejet it.. If you aren't up to tearing the carbs apart, go back to a new stock filter..
edit: I see you already have a DynoJet kit.. hmm You will need someone with more experience than me to guide you.
Old Dec 9, 2008 | 12:16 PM
ericb269's Avatar
kneeedragger
No I think your right because the guy I bought the bike from told me it had a dynojet kit but he also told me it had a k&n filter in it.hmmmmmmmmmmmmm ya right so I will with your advise and rejet it.
Old Dec 9, 2008 | 02:44 PM
drew_c14's Avatar
I would take a look first and try to see what's in it before buying anything. Also is it popping on decel? If so it could be the pair system, if it's still on the bike. The popping is usually caused by a lean condition, but there are several things that can cause that.
If the pair doesn't solve the problem try running it with the choke pulled out and see if it makes the problem better or worse. That will give you a better idea I think.
lynchie
Apr 23, 2011 01:42 PM
jonymo
Aug 2, 2010 06:53 AM
mattvdsande
Mar 16, 2009 11:12 AM
TheRezyReb
Apr 21, 2008 07:22 PM
