airbox
Old Feb 9, 2011 | 07:09 PM
waterbug89's Avatar
waterbug89 is on a distinguished road
airbox
is it all right to run the air box with no top thi is how the bike was when i bought it, any info would be great
Old Feb 9, 2011 | 08:40 PM
get a top for it, without it you are missing a lot of your low end horsepower and gaining little to nothing up top. (unless the motor is full of custom parts)
Old Feb 9, 2011 | 09:08 PM
Old Feb 10, 2011 | 05:55 AM
waterbug89's Avatar
thanks got one on the way off ebay
Old Feb 10, 2011 | 10:34 AM
wyldryce's Avatar
You'll thank yourself immensely when you install it.
Old Feb 10, 2011 | 11:17 AM
ranchomice's Avatar
Does it run without it?
Old Feb 10, 2011 | 11:22 AM
Sure it runs, see: http://www.ablett.jp/bikes/vtr/air_box_lid.htm
But if you look at his dyno numbers on the last page, he gave up and went back to stock.
Old Feb 10, 2011 | 04:26 PM
waterbug89's Avatar
yes it runs pretty good but to me it fills like it could be jetted, thats why i ask i am used to 2 stroke motors on jet skis so i thought i would ask it runs pretty good but at idle you hit the throttle and it hesitates a little and get mild back fire some times at lower rpm but seems like there sould be a little more?
Old Feb 11, 2011 | 08:02 AM
A lot more.. This motor should be strongest at the lower RPMs, with no need to rev it to get into it's powerband.
The airbox mod will move the powerband up to higher revs where this engine isn't suited to run.
Basically if you can't power wheelie in 1st & 2nd (strong runners even can do 3rd) it isn't running right. That doesn't mean it should wheelie every time you whack open the throttle, but it does mean if you want to wheelie you shouldn't have to rev it and dump the clutch.
kshuart
May 11, 2009 08:26 AM
mikstr
Apr 25, 2007 08:30 PM
mikstr
Mar 21, 2007 02:32 AM
mikstr
Feb 14, 2007 05:35 PM
EngineNoO9
Sep 11, 2006 01:16 AM
