Air Cut Off Valve
Old May 19, 2008 | 12:36 PM
1baddoggie's Avatar
1baddoggie is on a distinguished road
Air Cut Off Valve
I have been troubleshooting my deceleration popping and was wondering if anyone has every tested the air cut off valve? Engine braking (the manual calls it) popping out the exhaust is cause by a too lean condition and the air cut off valve is suppose to cut the air supply to the pilot system at some given level of vacuum thereby richening it for that condition. The manual does not state what vacuum point it should close/open.
The bike configuration;
2 Bros slip on
PAIR valves have been blanked off
All emission removed (CA)
It has stock jetting
I have checked for air leaks and that seems good
I pulled the carbs a second time to check everything over and looked at the air cut off valves, that is when I came to the issue of being able to check them accurately.
Thanks
Old May 19, 2008 | 01:21 PM
RCVTR's Avatar
My 49 state bike didn't have air cutoff valves. when I put 2 bros slip-ons on it I started to have lean decel popping. A #45 pilot jet was the cure.
Old May 19, 2008 | 01:51 PM
drew_c14's Avatar
This might be a stupid question, but...
When you removed the pair you did block off the vacuum ports right?
Old May 19, 2008 | 03:53 PM
There is a procedure in the manual for checking them, though it doesn't give a specific vacuum spec for it.
Old May 19, 2008 | 05:03 PM
1baddoggie's Avatar
Yes, and the one for the Evap system.
Old May 19, 2008 | 05:07 PM
1baddoggie's Avatar
Yes, kinda odd since they do give it for testing the PAIR valve. You would want it to engage and dis-engage at the right vacuum points...you'd think...
1bd
Old May 19, 2008 | 05:15 PM
1baddoggie's Avatar
#45 is the stock pilot jet. You are saying you went up a size on the pilot and that cured it?
The Last Gunfighter
May 18, 2014 06:48 PM
shwinny
May 21, 2011 02:48 AM
LeanRider
Jun 12, 2007 09:42 AM
klicks
Nov 20, 2006 02:46 PM
CNI Dawg
Nov 16, 2005 10:07 PM
