Advice: The bike has sat for a year w/gas
Old Apr 26, 2013 | 06:21 PM
Kendrick's Avatar
The Hypno-Toad
Hi Forum,
It's been a while. Due to a hand injury followed by a back injury the bike has sat for about a year in the garage. I got it started back in fall for a little bit. It would idle with the choke open, but would die if revved. The gas has Stabile in it but I doubt if that matters at this point. The battery is undoubtedly dead. But the bike is covered, has new tires, and generally was a good runner (except for the CCT's and electrics) before all this. I have a free day and finally decent weather here in WI to deal with this. Where would you begin?
Kendrick
Old Apr 26, 2013 | 06:25 PM
Jets are clogged...
My mental sanity is way to important to me to clean jest these days only to get it back together and have jetting issues from a still partially plug, nicked, damaged jet..
So I just replace um, every bike every time.c
So my opinion... order new pilots and mains, then disassemble, clean, install new jets and a new fuel screw O rings..
Old Apr 26, 2013 | 06:30 PM
Kendrick's Avatar
The Hypno-Toad
Dammit, I wanted the answer with the method to half-*** it and get it going, but you make too good of a point. Thanks, sanity is useful.
Old Apr 26, 2013 | 07:09 PM
If you have more time and interest in tinkering than money or want for a first time shot at getting it running.. By all means pull the seat, tank, airbox and carbs. Go though them, lost of solvent and compressed air.. NO HARD WIRES in passages or jets.. Clean with chemical or soft brush instrument.
Do not dip carb body in old style carb cleaner dip...
Once clean, put er back together and see what happens.
Old Apr 26, 2013 | 10:27 PM
supermarto's Avatar
Mine sat for two yeara. Same symptoms. Do you really think the mains need to be changed also? I KNOW my pilots were clogged, but the mains too?
Old Apr 27, 2013 | 09:23 AM
Likely not the mains, and you don't have to change anything, just clean. The mains are huge compared to an I4 or something smaller displacement, and don't easily clog. Still, if you're in there, it only takes 10 seconds to screw out the mains and another minute to clean each one. I like using a single strand of copper wire to clean the pilots. The hole in the end is smallest and most difficult to clean. Poke the strand through the large end, thatta way you know when the gunk comes out.
Mike996
Nov 5, 2009 06:43 AM
uchi
Oct 6, 2009 01:16 AM
REDVTR1000
Sep 15, 2008 09:57 AM
smack doogle
Aug 19, 2008 11:21 AM
L8RGYZ
May 9, 2008 06:03 AM
