Adjusting carb needles question
Old Nov 13, 2011 | 10:41 PM
Matt_Hawk's Avatar
Wild Man
Can you get into the diaphragm cover on the front carb to adjust the needle position without taking the carb out? I forgot if I had access when my tank was off.
thanks.
Old Nov 14, 2011 | 12:23 AM
bass4dude's Avatar
bass4dude is on a distinguished road
thanks.
Yes, you can get it off.
But no... You'll have a devil of a time getting it back in and will likely damage/mis-align your diaphragm.
I don't know if anyone else has been able to successfully do it but I wasn't, but then again I didn't spend all that much time trying.
It takes like 5 minutes to get the carbs off once you've got the airbox off.
My recommendation is a 1/4 x 8 extension with an 8mm bit on the end. It makes it a breeze to get to the clamps. You probably don't even have to disconnect the water lines, just to get the carbs where you can rotate them to have a good working plane.
Old Nov 14, 2011 | 10:21 PM
Matt_Hawk's Avatar
Wild Man
True..thanks!
I've noticed when the air is cold (48F) and I am at sea level, the bike is on the edge of being lean. However, in warmer (80F) air or a couple thousand feet higher, the bike is perfect.
Gotta love carbs.
Old Nov 15, 2011 | 01:27 PM
bass4dude's Avatar
True..thanks!
Gotta love carbs.
You shouldn't need to adjust the needles for something as small as that.
That is more an A/F screw range. You're jetting necessities shouldn't be changing that radically with only a few thousand feet or even 30 degrees.
I think the spec is 1/2 in for altitude, so you'd just wanna go with 1/2 out if you're running lean.
And which one do you ride more frequently in? I set mine for my commute at a little rich at sea level, then when I hit the twisties I just knock it back 1/2-1/4 of a turn pending on temp... ect.
It's been tempting me to buy a flo-commander having to adjust it as much as I do!
sorny
Oct 25, 2014 06:00 AM
GTS
May 1, 2012 04:38 PM
uchi
Apr 8, 2010 10:20 AM
Tysonb
Nov 24, 2008 12:58 PM
roadrun_fr
Aug 30, 2005 09:49 AM
