99 superhawk with audible crack from engine. Cylinder cutting out
Old Jun 21, 2019 | 04:30 PM
Donwallace's Avatar
Donwallace is on a distinguished road
Hey all. New to the superhawk life. Picked up a 99 hawk for cheap. No fairings and what not. Was given the “street fighter” effect. It definitely needs work. However I listened to it run previous to purchase. It all sounded good for the limited time it ran. Short story long I transferee title today threw it in my work truck and unloaded it at my shop. Did a few road calls and came back at the end of the day. Brought fresh gasoline. Fired her up with some choke and let her idle. Cut the choke and gave some throttle. Starts cutting out as if carbs need cleaned. However after about a minute or two of higher throttle (maybe 3k) I heard an audible crack from engine and lost a cylinder. Assuming rear. Engine died out gradually. Started her right back up without choke and ran fine. A minute or two later same thing happened. Audible crack running on one cylinder. Held idle until another crack was heard and ran on two cylinders again. Carbs need cleaning for sure but I can’t imagine throttle plates sticking like that and making a crack all while under steady load. Anyone ever experience anything like this. I took a video on my iPhone but not sure how to upload it yet
Old Jun 23, 2019 | 03:09 PM
YMRacing's Avatar
Dirty carbs.
Old Jul 2, 2019 | 02:37 AM
ACE VenTRa's Avatar
I will say that when I first had mine and it had been sitting for many years, it had a tendency to misfire on one cylinder and while I wouldn't quite describe it as a cracking noise, it was concerning. As much as valve adjustments and carb cleaning sucks on these bikes, I would say it is the first thing you should do as well as check the cam chain tension. Start there. I would.
AV
Old Jul 23, 2019 | 11:08 PM
Ohtwohawk's Avatar
Ohtwohawk is on a distinguished road
Crack noise
I have a 02 996 and everyone and a while be cruising at a lower idle and I'll get what a call a motor cough or hiccup other than that runs mint aftermarket tensioners... any ideas?
Old Jul 24, 2019 | 07:49 AM
Wicky's Avatar
Carb fart - spitting back into airbox is pretty common. Just set the carbs up, balance them and set TPS to spec and fingers crossed. If still occurring esp when on the move which risks stalling it in low speed turns with embarrassing consequences - just up the idle to 1200–1300rrpm
Exo
May 7, 2013 12:24 PM
jdobeckj
Sep 18, 2012 07:26 AM
babyhawk
Feb 12, 2011 09:40 AM
trinity012
May 22, 2007 06:22 PM
lovemyhawk
Mar 27, 2007 01:00 PM
