929 wheel on rc51 sp1 front end
You'll definitley need to swap the bearings out... I think 929's are 25mm... the RC's are stupid 22mm (I say stupid because every standard bearing kit remover comes with 20mm and 25mm "removers"... of course the RC has to be difficult.)
I'd guess if the rotors bolt up in the right spot, the bearings should be all you need... maybe some spacers at worst.
Whoops.... Yeah, I missed that... (monday mind thing).... the rotors are larger... I though you were using RC rotors on the 929 wheel.... I'd bolt it up and see where everything nets out.... might be close.
You could have new caliper brackets made.. but it's much cheaper to buy a set of rotors... most go in the 100 dollar range used for a set.
inderocker
Nov 2, 2009 02:08 PM
inderocker
May 29, 2009 05:53 AM
FL02SupaHawk996
Apr 19, 2008 03:45 AM
Flight_996
Jan 6, 2007 04:19 PM
