900rr Rear rim question
Old Nov 17, 2011 | 02:54 PM
selztoad's Avatar
What year rear 900rr rims are compatible with our hawks? I am installing a rear PM chicane rimfrom a 900rr off a 1995 and the spacer for the chain side is about 2mm too wide, i have a buddy who is a machinist and can make a new one but I am not sure how much 2mm may/will effect things?
Old Nov 17, 2011 | 03:26 PM
nath981's Avatar
well if the brake caliper is lining up(centered) with the rotor and the rear sprocket is in line with the front sprocket, you should be able to tell easily. If you have a bench grinder, or even sandpaper on a flat surface and a cheap mic, you can easily grind the spacer down to see if you can get it to work. Make sure you allow for the insert if the bearing isn't flush with the wheel surface.
Old Nov 17, 2011 | 03:30 PM
JamieDaugherty's Avatar
It's a direct swap - they are dimensionally identical. Bolt it on using all of your stock VTR parts and you will be fine.
Old Nov 17, 2011 | 03:43 PM
+1 Yeah it should just bolt right up.
Old Nov 17, 2011 | 04:18 PM
selztoad's Avatar
Cant use stock spAcers though as the rim doesn't use the Cush drive . The rotor lined up perfect so my friend made me a spacer that fits the sprocket side but I was not sure if that would take the rim off center
Old Nov 29, 2011 | 03:52 PM
REDVTR1000's Avatar
I am using the Cush drive off the vtr in mine. Why do you say it wont accept it?
Old Nov 29, 2011 | 04:01 PM
selztoad's Avatar
Its a performance machine aftermarket rim
Old Mar 14, 2012 | 06:58 PM
qfo's Avatar
qfo
qfo is on a distinguished road
So you guys are saying that a 900rr wheel is a straight swap, and i could use the cushions and caliper bracket from the vtr? which years fit exactly? (except the 929/954 because you already said the shaft is 25mm)
Old Mar 14, 2012 | 08:37 PM
RWhisen's Avatar
Former Superchicken Owner
Cush drive is installed.
Old Mar 15, 2012 | 03:01 AM
REDVTR1000's Avatar
Dunno, even with out using a cush the sprocket carrier should still mount to the hub with a stock profile. If it bolts to the back of a 900rr than it should bolt to the back of a vtr. This one is a head scratcher without seeing the rear with the carrier off
Old Mar 15, 2012 | 06:50 AM
qfo's Avatar
qfo
Well im asking this because there are a couple of rear 900rr rims on ebay, but when the guys are selling them with the disc and cush drive, they ask 100$ more.... So I will take your word for it and buy only the rim and use the VTR disc and caliper bracket and hub....lets hope it works!
Old Mar 15, 2012 | 08:55 AM
REDVTR1000's Avatar
I bought a standard 900rr rear and bolted my hub, sprocket, and cush to it and used stock spacers. Brake also bolted right on. It is a direct swap.
Old Mar 15, 2012 | 09:38 AM
Yes, the cush drive and related parts are the same. The caliper bracket is also the same.
Old Mar 15, 2012 | 09:41 AM
qfo's Avatar
qfo
Thank you for the confirmation!
thedeatons
Aug 2, 2013 04:40 PM
D VTR RIDER
Dec 13, 2011 05:08 PM
selztoad
Oct 27, 2011 09:20 AM
EvlDrPorkChop
Jun 5, 2011 11:11 PM
Erik S.
Feb 3, 2010 02:23 PM
