30 mm offset triple clamps?
Old Jun 4, 2009 | 01:15 PM
vtrktm's Avatar
vtrktm is on a distinguished road
I'm looking to reduce my fork offset to 30 mm from the std 35mm but for economic reasons wish to retain the stock forks which I've already upgraded the internals plus I have marchesini wheels that fit and don't want to swap everything out, etc.
So does anyone know of any 30 mm offset clamps from another model that will accomodate 41mm forks and fit the 'Hawks steering head?
Tx!
Old Jun 4, 2009 | 01:23 PM
VFR perhaps?
Old Jun 4, 2009 | 01:30 PM
vtrktm's Avatar
I think they are around 35mm too but I'll try to measure some.
Old Jun 6, 2009 | 06:55 PM
Fozzy Bear's Avatar
Fozzy Bear is on a distinguished road
Maybe its too early in the morning and I cant think straight, but wouldn't reducing the offset, increase the trail and slow the steering?
Old Jun 8, 2009 | 05:09 AM
Albeit a bit expensive perhaps, you could try fitting a 1998-99 CBR900RR front end as it features a 30 mm offset (earlier models were at 35 mm). In addition to getting the offset you want, it is also much more rigid and gives you compression adjutability. I am running forks from a 96 and so have the 35 mm set-up.
Just a thought....
Aas for Fozzy, you are correct. In the case of the aforementioned 900, the offset was reduced to increase stability.
Old Jun 8, 2009 | 09:21 PM
RCVTR's Avatar
Yes it will. It's necessary when you increase the rear ride height and steepen the head angle. And ride the **** out of it to the point where you need more trail for stability.
5 mm is a lot. From what I've been told 32.5 is the good offset number. 30 mm will probably make the steering overly heavy.
Old Jun 18, 2009 | 07:20 AM
nath981's Avatar
can you remove the clips on the forks and raise the front up a bit?
Harris make an adjustable yoke for about a grand.
Old Nov 2, 2009 | 06:40 PM
Rama's Avatar
Rama is on a distinguished road
The original offset was 35mm?
I ask because I hav'nt the original forks and clamps, and I need the exact quote for the new clamps....
Old Nov 13, 2009 | 04:42 AM
Rama's Avatar
Anyone can confirm the 35mm offset in the original VTR F configuration? Thanks!
64BitCarbide
Jun 12, 2011 09:17 AM
mikstr
Apr 16, 2010 06:03 PM
hondavtr1000sp2
Aug 13, 2009 02:27 AM
tackybiltpro
Jan 20, 2008 08:13 PM
vtrktm
Dec 31, 2007 03:38 PM
