2003 honda superhawk 996
Old Aug 4, 2023 | 02:10 PM
drasken's Avatar
drasken is on a distinguished road
Hey people of the Honda superhawk world.
I have a 2003 honda superhawk 996
today I was riding home and something poped and the bike lost power and avenchly died i was able to start it 2 twice after it died and then it would not restart after that I tryied to limp it home to no avail had to be pulled home. Any ideas of where I should start on trying to fix this issue
Okay so talked to my mechanic and we are thinking that maybe my battery is dead and not being charged so charging my battery as we speak also yes I do have a manual but I need to sit down and look through it
Old Aug 4, 2023 | 06:10 PM
Do you have manual or automatic cam chain tensioners? If automatic, check compression to rule out a timing jump resulting in bent valves.
Old Aug 5, 2023 | 03:36 PM
On the attempted restart, did the starter turn the the engine over? Not clear from your description. Obviously if it did, it's not the battery.
Old Aug 5, 2023 | 06:13 PM
drasken's Avatar
Yes once I got a charge back on the battery the motor turned over and started with a loud clinking sound I have a video audio clip of it but I can't posted it on this forum but if your willing to see and listen send me a message via Facebook look for Ryan bogdanich my profile pic is of a creepy eye
Old Aug 6, 2023 | 06:19 AM
Doesn't bode well for the health of the engine. Have the stock auto cam chain tensioners been replaced with manual?
Old Aug 11, 2023 | 12:35 PM
drasken's Avatar
. So had A mechanic look at it and pulled the head cover to find that my rear timing chan tensioner is indeed done and messed up so needs a new timing kit as well as the motor skipped and valves are bent.. only saveing grace about 3 years ago I bought a crated motor for this motorcycle in hopes I could drop the other and gut it and make it better. Was not able to that project so now I have a fully functional created motor that I get to swap
my question is what will I need for this
Old Aug 14, 2023 | 10:10 AM
ZKarma's Avatar
Always good to have a few spare parts laying about, seals...gaskets....crate motor, just the basics.
Old Aug 14, 2023 | 02:55 PM
drasken's Avatar
just wish I could be more of a Mechanic and pull the old motor and swap it
Old Aug 16, 2023 | 11:18 AM
killer5280's Avatar
You can do it.
Old Sep 9, 2023 | 08:15 AM
Hangfly's Avatar
Yes. You can do it. If you identify your general location in you signature, maybe you can make a local mechanic friend who will help.
And read all the posts related to the task at hand. Also:
".....my question is what will I need for this?"
Manual chain tensioners .
Old Sep 9, 2023 | 05:09 PM
drasken's Avatar
It's in the air now old motor still inplace but everything is ready to drop true
Well the motor is still In place but I have the swing arm off exhaust is off and in peicese the frame bolts are all lose all I need to do is remove one more pesky 10mm bolt that attaches to frame cooling resivore and no socket cant work there and don't seem to have a 10mm wrench go me
Old Sep 10, 2023 | 01:09 PM
fabiostar's Avatar
before you put the new motor into it, change the autos to manual on the new motor or you will be doing the job all over again.
Old Sep 10, 2023 | 01:16 PM
drasken's Avatar
not sure how to even do that so will look into it
Old Dec 16, 2023 | 04:54 PM
drasken's Avatar
So good news I swap the motor its in and I have been trying to peice it back to geather my issues now are the water lines and the vacuum hoses I am trying to find a good walkthrough video or pics that show where each go correctly as well as needing it done before the end of the weekend
tapatio
Aug 31, 2016 06:48 AM
tewolf24
Jun 14, 2015 06:55 PM
NH-Raptor
Feb 18, 2010 08:13 PM
superhawkslider
Sep 2, 2008 01:22 PM
bigpat123
Dec 12, 2005 07:48 PM
