2003 honda superhawk 996
Hey people of the Honda superhawk world.
I have a 2003 honda superhawk 996 today I was riding home and something poped and the bike lost power and avenchly died i was able to start it 2 twice after it died and then it would not restart after that I tryied to limp it home to no avail had to be pulled home. Any ideas of where I should start on trying to fix this issue Okay so talked to my mechanic and we are thinking that maybe my battery is dead and not being charged so charging my battery as we speak also yes I do have a manual but I need to sit down and look through it |
Do you have manual or automatic cam chain tensioners? If automatic, check compression to rule out a timing jump resulting in bent valves.
On the attempted restart, did the starter turn the the engine over? Not clear from your description. Obviously if it did, it's not the battery.
Yes once I got a charge back on the battery the motor turned over and started with a loud clinking sound I have a video audio clip of it but I can't posted it on this forum but if your willing to see and listen send me a message via Facebook look for Ryan bogdanich my profile pic is of a creepy eye
Doesn't bode well for the health of the engine. Have the stock auto cam chain tensioners been replaced with manual?
Originally Posted by xeris
(Post 415886)
my question is what will I need for this |
Always good to have a few spare parts laying about, seals...gaskets....crate motor, just the basics. :D
Originally Posted by ZKarma
(Post 415899)
You can do it.
Yes. You can do it. If you identify your general location in you signature, maybe you can make a local mechanic friend who will help.
And read all the posts related to the task at hand. Also: ".....my question is what will I need for this?" Manual chain tensioners . |
It's in the air now old motor still inplace but everything is ready to drop true
Well the motor is still In place but I have the swing arm off exhaust is off and in peicese the frame bolts are all lose all I need to do is remove one more pesky 10mm bolt that attaches to frame cooling resivore and no socket cant work there and don't seem to have a 10mm wrench go me
Originally Posted by Hangfly
(Post 415933)
before you put the new motor into it, change the autos to manual on the new motor or you will be doing the job all over again.
Originally Posted by fabiostar
(Post 415935)
So good news I swap the motor its in and I have been trying to peice it back to geather my issues now are the water lines and the vacuum hoses I am trying to find a good walkthrough video or pics that show where each go correctly as well as needing it done before the end of the weekend
