2000 Firestorm not sparking on front cylinder
Old Apr 1, 2016 | 08:29 AM
chrisuns's Avatar
chrisuns is on a distinguished road
Cool 2000 Firestorm not sparking on front cylinder
Hi Guys, after years of riding a Triumph i recently bought a 2000 firestorm as a fixer upper to use as a second bike!
Apologies for jumping straight in with a technical request but i am led to believe you honda guys are very welcoming!
The issue i have is it will not run! There is either no spark or if you are lucky when you press the starter you may get a single spark from the front cylinder. The back cylinder sparks every time without fail!
Here is what i have tried so far!
1. Switched front and rear coils, front coil fires fine on rear plug but still no spark to front!
2. Metered cable from igniter/converter unit to front coil and appears fine
3. Added independant earth to front coil to no avail
4. Split wires coming from ignitor/converter and switched trigger wires for coils between front and rear which transferred the fault so definitely not a wiring issue after the converter
5. Tried a different converter and ignition control module but the fault still exists.
When you turn the bike over with a plug in the lead to earth you get no spark, occasionally if you stop and start the starter button you may get a single spark from the front plug but thats it!
Any help would be greatly appreciated from you guys!
Old Apr 1, 2016 | 09:07 AM
Wicky's Avatar
Greetings
Have you downloaded the Honda Service Manual PDF?
See Section 17 - Ignition System and the Troubleshooting section that deals with weak / no spark fauly testing procedure
Old Apr 3, 2016 | 12:39 AM
chrisuns's Avatar
Hi Wicky,
many thanks for the response and information. Downloaded the stuff and carried out the checks and voltages all ok.
Removed the plugs and turned it over and low and behold both pots spark so suspect it is slow turning over but unsure why!
I removed the plug on the genny cover and turned it with a socket and felt a bit rough so removed the starter and tried again and is much smoother although starter doesn't feel overly tight!
Any suggestions?
7moore7
Mar 22, 2011 01:41 PM
Kymera
Jan 18, 2009 12:11 PM
trace33chargers
Oct 1, 2008 09:10 PM
redshirt
Jun 8, 2008 12:34 PM
J-Bird487
Sep 21, 2007 10:39 AM
