15T sprocket ?
Old Jan 30, 2008 | 11:19 AM
bigmike1219's Avatar
bigmike1219 is on a distinguished road
15T sprocket ?
Ok a new guy question, how hard is it to change the front sprocket?
I have a 520 kit I want to install, the back is not a problem and yes I do have a chain tool.
thanks
Old Jan 30, 2008 | 12:14 PM
Blue Ridge Boy's Avatar
Not hard at all.
Just unbolt the cover, take off the nut holding the sprocket tight (this nut may be very tight if you have never messed with it). Slide the sprocket off and slide the new one on and bolt everything back up.
Old Jan 30, 2008 | 12:24 PM
Thanks, my project for this weekend
Old Jan 30, 2008 | 12:27 PM
To just install the front sprocket?
It will only take you about 15-30 minutes as long as you keep all of your bolts organized, which by the way, pretty much all the bolts on the sprocket cover are different lengths, so label them so you are not lost latter on when you can't remember what went where.
Old Jan 30, 2008 | 07:33 PM
Thanks for the tip, I am installing the 520 kit 15/43
Old Jan 30, 2008 | 08:08 PM
Hotbrakes's Avatar
You're gonna love it!
Threading the chain around is the hardest part.
Old Jan 31, 2008 | 01:56 PM
Make sure you don't have the cover off for too long. The slave cylinder will work its way out and will draw air into the clutch master cylinder. This is a major pain in the *** to resolve. Also, use the rear brake to hold the output shaft steady as you loosen the countersprocket bolt.
LineArrayNut
Oct 5, 2009 03:25 AM
reaper
Oct 19, 2007 06:45 AM
duran
Aug 27, 2007 07:57 AM
trickphoto
Jul 19, 2005 05:55 PM
mrjakeanderson
May 21, 2005 09:13 AM
