1/4 throttle issue
Old Jun 19, 2012 | 03:21 PM
maniac2313's Avatar
maniac2313 is on a distinguished road
1/4 throttle issue
Got my bike up and running but found an issue when i got on the highway for the first time... while riding around town in varied throttle positions the bike runs good for a rough tune pulls all the way no spikes no drop offs in power good temps etc... but when cruising at highway speed at 1/4 throttle it looses power backfires bucks and runs like **** only after cruising for 10-15 mins at first its fine pull over let idle for a minute and its good for another 10-15mins then it starts again... pulling the choke makes no difference no better no worse... when its bad it kind of feels like the petcock is hooked up wrong but I checked and its not... I assumeits in the jetting i have a fp ti jet kit with 50the pilots needles in the center 178 front main 180 rear... she pulls and will pull up the front in first and second on stock gearing and is good riding through town but hates cruising at the same speed any thoughts? I have mori cams valves je hc pistons dr honda velocity stacks and a stock filter pair removed...
Old Jun 19, 2012 | 04:02 PM
The pilot jets are too large
Old Jun 19, 2012 | 04:22 PM
GTS's Avatar
GTS
Seasoned tech
I have to agree. Mine had 50 pilots in it when I got it with the FP jet kit. I think it had the same mains in it as well. I went through the carb thread and put 48 pilots and 75/78 mains in it, needle in middle position and screws 2.5 turns out and it ran perfect. In an effort to try to get a little better mileage I dropped the needles one position and it ran great everywhere except while cruising up to about 3000 rpm where it pops back in the carbs. Didn't seem to help mileage so I'm going to go back to the middle position on the needles.
Old Jun 19, 2012 | 05:18 PM
maniac2313's Avatar
I have keiln 45 and dj 45 pilots should i run either of these till the 48new pilots i just ordered come in or leave it alone because they will be too lean? Im assuming they will be too small and it will run lean...
Old Jun 19, 2012 | 05:23 PM
maniac2313's Avatar
Old Jun 19, 2012 | 07:47 PM
GTS's Avatar
GTS
Seasoned tech
I'd just wait till you get your new ones. No point in tearing it apart twice. What all do you have done to the bike?
Old Jun 19, 2012 | 08:28 PM
It wouldn't hurt to run the 45s right now. You would be down on power slightly on the low end but it should cure the loading up issue you are having.
Though if you have 48s on the way it would be up to you if you want to pull the carbs twice or not.
Old Jun 19, 2012 | 09:17 PM
maniac2313's Avatar
Yea im waiting for the 48s it only takes half hour but its not worth it ive waited this long i want it right... gts I have basically built a stg 1 motor stacks pistons cams valves...
Old Jun 19, 2012 | 09:53 PM
Have you done anything to the slides? With the stacks you can do one of 2 things to overcome the tendency they have to run rich in the mid-range.
Either drop the mains down 1 size or plug a lift hole in each slide.
If you read my carb set up thread it covers this and you really should do the slide mod if you want the bike to run properly.
Old Jun 20, 2012 | 01:33 PM
maniac2313's Avatar
Did the slide mod when i put the stacks in and I do have the stock needles ordered them just in case but I dont think ill need them...
Old Jun 20, 2012 | 01:56 PM
No worries, just wanted to check because they can also cause the issues you were talking about by going rich in the mid-range.
Also you should have no real issues with the FP needles.
Old Jun 20, 2012 | 02:09 PM
GTS's Avatar
GTS
Seasoned tech
I think I'd probably stick with the FP needles with your set up as they are easier to adjust if you need to and have a lost more adjustability as well.
Old Jun 20, 2012 | 07:20 PM
maniac2313's Avatar
Thanks for the info hawk and gts!! i will update when the new jets come in till then she will be in the garage!!!
Old Jun 28, 2012 | 02:06 PM
maniac2313's Avatar
So I got the jets in and its better at a cruise but when you try to go up it doesnt seem to have the punch it should... is that the needles?
Old Jun 28, 2012 | 02:12 PM
Generally yes. Whether it is rich or lean is what you would need to figure out.
Try the choke trick to see if it runs better with it out (a lean condition) or worse (a rich condition) and then adjust the needles.
Though by reading your first post it sounds like you have the needles in the center groove. So I bet you are rich in the mid-range and I would just drop them one notch as a start, but that is just me...
Old Jun 28, 2012 | 02:40 PM
maniac2313's Avatar
Thanks will drop them tonight! So down with the needle height leans it and raising richens correct? Sorry im not the best with carbs... the choke made very little difference but it was worse...
Old Jun 28, 2012 | 03:23 PM
Yes dropping them leans it out and raising them makes it richer in the mid-range
Old Jun 29, 2012 | 08:35 AM
If you pulled fuel by going to smaller idle jets then you might want to consider adding a bit more fuel in the mid and upper ranges (needles and main). Like 8541Hawk said, use the choke to determine if you're lean or rich.
Also, double check your carb sync and that the tank vent hose is clear of obstructions and kinks. It just sounds a little strange that an overly rich idle jet would foul your plugs while operating in the mid range. Sounds like a fueling issue to me, like the petcock you mentioned, but you already checked that. Might try pulling a plug right after it happens to see if the plugs are really fouled.
Old Jun 29, 2012 | 01:42 PM
maniac2313's Avatar
The plugs arent fouled its just lacking the punch it should... I think its rich i moved the needles will ride it tonight to see for sure...
Old Jun 30, 2012 | 10:01 AM
maniac2313's Avatar
Its good enough to ride through the break in process... then i will do a fine tune on the dyno! Cant wait I'm happy with it now still have a few mods to go but im getting there!
Old Jun 30, 2012 | 10:03 AM
Sounds like we got you close at least.... glad to hear it is running better for you
Old Jun 30, 2012 | 10:49 AM
maniac2313's Avatar
Its very close I cant wait for the dyno!! Thanks !!!
rigoshawk
Sep 6, 2007 06:27 AM
azhawk1
Mar 3, 2007 08:34 AM
call me phil
Feb 24, 2007 04:18 AM
Lefin102
Dec 27, 2006 03:23 PM
nuhawk
Dec 1, 2006 11:15 PM
