Throttle position sensor question
Old Aug 30, 2007 | 09:44 PM
rigoshawk's Avatar
rigoshawk is on a distinguished road
Talking Throttle position sensor question
I set my tps to 510ohm's and did notice a smoother throttle or not so choppy throttle control. However, I also noticed that it does not have as much quick throttle response off the line as it did. My question: is the tps set at closed throttle with standard idle setting on the throttle plate or "fully closed" throttle with the idle screw backed out all the way?? I did'nt notice this information in the service manual but am guessing that this can be a significant difference? I am uncertain to what the ignition timing curve is on this engine but, do know that the spark does have to advance on a reving engine significantly. I have no regrets of doing the mod; simply because I now have 6mm bolt heads to loosen and easily adjust.
Old Aug 30, 2007 | 10:18 PM
Chitownson's Avatar
Chitownson is on a distinguished road
I just adjusted my TPS at regular idle. The adjustment does take away the feel of some low end grunt initially, but my sense is you get much more control, being able to whack the throttle faster and off the line quicker, with the bike steadier. The TPS adjustment also makes the acceleration more linear, allowing me more throttle control in the twisties (lessens the feel of the back wheel coming out from under you in a turn under acceleration.) Over all, the bike will behave a bit more refined; you'll notice the exhaust tone changes a little too; I would also synchronize the carbs while you're in there.
Old Aug 30, 2007 | 10:31 PM
rigoshawk's Avatar
TPS
I agree. I did synch the carbs with a carb-tune tool. I got the balance about perfect and it idles beautiful at about 1050 rpm's.
Still curious to throtle plate position though.
Old Sep 5, 2007 | 09:03 PM
rigoshawk's Avatar
TPS
Anyone else with throttle plate position while adjusting tps info??
Old Sep 6, 2007 | 06:27 AM
I had done the TPS adjustment and went back to stock settings (700 and something, I forget exactly) for the exact reason listed: I missed the bottom-end snap. I also did not see or feel any benefit whatsoever from dropping it to 500 ohms so back it went and bingo, instant bottom-end.
Hawkrider
Oct 31, 2018 04:11 PM
smokinjoe73
Nov 9, 2010 09:39 AM
CentralCoaster
Nov 27, 2008 08:45 PM
mamisano
Nov 13, 2006 10:06 AM
