01+ models - average running temp?
Old Sep 14, 2009 | 09:59 PM
joshuatest's Avatar
OUCH... MY A$$ HURTS!!!
ok guy's...
don't beat me over the head... I did search... but can not find a actual answer...
On the 01+ models that have the digital temp gauge... What temp does it normally read (or what temp range)
When sitting at a light, in town riding what do you see?
On the open road at 5k plus rpm, what do you see?
and at what average daily temp are we talking?
thanks....
In town, I've been seeing about 225 on average on a 85+ deg day... I don't think i've seen over 230 before.
On a cool day, open road, i can keep 185 or so... But generally I think i spend most of the time at 218-219... which I always seem to notice because the fan kicks on at 219 i think....
also... anybody know what temp the thing starts overheating or blinking red at?
Old Sep 14, 2009 | 10:12 PM
I've seen 235, once, while in traffic with lots of stoplights and 103 degrees.
Otherwise it will hit as high as 220+ in the summer, 80s to 90s outside temp. Low to mid teens canyon riding in summer with outside temp in 90s. Winter canyon riding won't even hit 200.
Oh, and mine's an 05.
In winter traffic with stoplights and temps in the 50s to 60s the fan will still come on some times at the temps you mentioned. Steady riding hits about 180 to 190+.
Old Sep 14, 2009 | 10:25 PM
Spaz''s Avatar
Spaz' is on a distinguished road
Even riding in the summers around here in the Pacific Northwest during our occasional 95F+ weather has it ever gotten past 216F on the temperature gauge. Maybe 217-218F rarely, but I'm totally guessing. I really don't think I've seen it higher than 218F. Maybe 220F. … :P ...I really have no clue. It does seem to run better though when it makes it to 200F+ however. These are the only real temp' numbers that I've ever paid attention to really. But in the winter I'm curious what I am pulling, as I ride only when it's dry out. And on the highway I'd say I do no more than 188F perhaps when it's about 55F out and I'm doing 60mph. I really don't know.
Anyhoo', these are my findings for my small note takings that I've pulled in during my time of owning my ride and monitoring the temp's.
Old Sep 14, 2009 | 10:26 PM
joshuatest's Avatar
Riding tonight it was about 80 deg, VERY humid (felt like 90's) and I was riding around in town a good bit... at a couple stop lights I was seeing 227-229... Seemed a tad high, but then again, who knows...
I think its just because I've been watching it this week more after debating trying to add the air intakes to the RC51 fairings... The vents on the sides only expose about half of each rad, and the inside of the rad's are completely exposed. So I really don't see that it even matters... i think its more of those in your head things you notice because you changed something... lol
I bought some of that HEAT stuff to add to my coolant, but never added it.. Guess this week when i do a oil change, i'll add that too and see if it makes a difference.
Old Sep 15, 2009 | 04:19 AM
Billzilla15's Avatar
180 - 220 depending on how hot its outside, cooling fan clicks on at 217... hottest ive seen is 225
Old Sep 15, 2009 | 05:23 AM
FL02SupaHawk996's Avatar
Fastest Color
my fan used to come on all the time around 219 cuz riding in FL in the summer is hot, but I've added air scoops and running down the road at 5K rpm it holds around 185 no matter what the temp is outside, so in traffic at stoplights it will get into the 200s, but the fan doesn't usually ever come on anymore
Old Sep 15, 2009 | 08:00 AM
joshuatest's Avatar
air scoops???
got any pictures? might be something i should look into
Old Sep 15, 2009 | 08:09 AM
Fastest Color
Originally Posted by joshuatest
air scoops???
here ya go!
Attached Thumbnails 01+ models - average running temp?-05-15-09-air-scoops.jpg   01+ models - average running temp?-06-09-09-air-scoop.jpg   01+ models - average running temp?-06-09-09-rt-air-scoop.jpg
Old Sep 15, 2009 | 09:25 AM
joshuatest's Avatar
Nice...
How pricey where those?
I took the pieces out of my stock fairings to see about fitting them to the RC51 fairings, but only looked at it one day and forgot about it. I'm gonna have to spend my next day off making that happen I think...
Old Sep 15, 2009 | 09:50 AM
Fastest Color
Nice...
They aren't cheap...I think I paid 325 Euros + shipping for the glass/carbon fiber set I'm running...here's the website & discussion about them on speedzilla:
http://shop.durbahn.de/shop/en/bikes...awk?bikecat=57
http://www.speedzilla.com/forums/hon...perhawk-2.html
Old Sep 15, 2009 | 11:44 AM
mattmcgyver's Avatar
mattmcgyver is on a distinguished road
WashMet area, 224F Max in S&G traffic, fan comes on at 216F Running never seems to get over 200F.
(2002 Stock)
Old Sep 15, 2009 | 12:09 PM
kai ju's Avatar
I shouldn't really chime in on this but here goes anyway:
Fan comes on at 207 and goes off at 194 all day long, regardless of ambient temp or speed. In colder temps it takes longer to reach 207 but the rythm stays the same.
It's been this way since I've installed the second fan a couple of years ago, after realizing that one fan was not enough with the under seat radiator.
Kai Ju
Old Sep 15, 2009 | 12:21 PM
yruyur's Avatar
218 generally but it's az and hot out here, do most my riding at night in the summer. Had it at 230+ one day in stop and go in the heat. Just did a coolant flush with water wetter last night seemed to drop about 5 degrees. Should be enough of a drop to prevent the fan from coming on. We did 65% water 35% coolant plus the water wetter that you can pick up at any auto store.
Old Sep 15, 2009 | 06:04 PM
You need to put up pics of the 3rd eye late night mod.
Old Sep 16, 2009 | 07:41 PM
alive226's Avatar
Mine seems to run a tad hotter than most of yours. I have an 03 and it will usually run in the 220-230 range on a 75-85 degree day. A few weeks ago I got stuck in some pretty shitty traffic on a 92 degree day and it ended up hitting 242 before I pulled over and stopped for a drink. It took me two and a half hours to get home in that heat... That was unusual and I don't recall seeing it over 230 more than once or twice.
On cool days, it will still easily hit 220-225.
Old Sep 16, 2009 | 08:10 PM
Why is everybody afraid of the fan. It comes on, it does its job. If your coolant isn't boiling out of the reservoir, you're okay.
Keeping a good radiator cap on there is super important also. Each PSI of cap pressure raises the boiling point by 3 degrees.
Old Sep 17, 2009 | 10:52 AM
tbartley's Avatar
Good advice! My 01 runs about the same as everyone above. Fan kicks on about 217-218 and turns off shortly thereafter. I've never worried about overheating and have only been to 219 on the gauge.
Old Sep 17, 2009 | 05:09 PM
joshuatest's Avatar
I'm not afraid of the fan... But i would like to know at what point its considered overheating.. My levels seem to be about 10 deg higher than most who posted here.... So i think a fluid swap, adding a toggle switch for the fan, and maybe even some air damns may be called for... I think performance is best around 200 deg... but for longevity of the engine, i don't wanna run it closer to the high side if i don't have to....
Old Sep 17, 2009 | 08:13 PM
yruyur's Avatar
If you put a switch in then put it in parallel with the thermostat so you don't lose the auto function but still have the ability to turn it on when needed.
Old Dec 18, 2009 | 06:02 AM
Spaz''s Avatar
Small update on engine running temp's
We were havin' some icy weather last week and I had gone for a small trip outside of town. On my way back into town a few minutes after 1700 (Rush hour traffic) I took note of what my engine temp' was.
It was stop and go traffic for a couple miles and it must have been at some 31F outside. I was drawn to see what my engine temp' had to say after I'd heard it go on at one point and I was right about 213F.
-Spaz
Old Dec 18, 2009 | 08:05 AM
Stevebis1's Avatar
I didn't search on radiator flushing, but I haven't seen it brought up much. Now that our bikes are getting older, I suspect that the variations in temp might be impacted by how often the coolant is changed and if a good flush is performed or just a draining.
My bike is a 99 so it only has the dial not the digital, but I saw a noticeable difference when I flushed and changed the coolant this past summer. I put nothing special back in (prestone 50/50 premix), but the fan comes on less frequently and the needle usually points a bit cooler.
I have no idea if the PO ever changed the coolant, I suspect he didn't. Probably changing and flushing every two years would help.
...and we could start a thread on which coolant is the best!
Old Dec 19, 2009 | 08:24 PM
nath981's Avatar
you're not even close to overheating. If you want to install an over-ride switch to quell your fears, help yourself, but the boil point for antifreeze under pressure is over 260 deg and quality oils handle higher temps without breaking down, and combustion is more efficient at higher temps. No harm running higher temps other than fallacious notions that anything over 180-195 is harmful.
If you have questions regarding optimal temps, there is wealth of info on this subject on the web.
Old Dec 20, 2009 | 01:40 AM
Spaz''s Avatar
Grammar correction
"I was drawn to see what my engine temp' had to say after I'd heard *the radiator fan go on at one point and I was right about 213F."
Sorry about that.
Old Dec 22, 2009 | 03:13 PM
tbartley's Avatar
Sorry about that.
I knew what you were talking about Spaz and most others here probably did, too. No big deal. I noticed that my 05 runs a little warmer than the 01 and I'm using Texaco Orange in both. Strange.....
Old Dec 22, 2009 | 06:10 PM
nath981's Avatar
for those fretting over temps of 230 or under, think about what kind of temps air cooled engines might be running for many years and thousands of miles. If you could gauge some of these, you would find temps spike well in excess of 230, even up to 260 with no harm done, that is, assuming quality oil. Use good oil and you need not be so concerned about these temps.
ZERO
Jan 25, 2015 01:34 PM
speedkelly@aol.com
Jul 31, 2007 01:37 PM
j-rocket
Nov 15, 2006 01:01 PM
ClevelandSuperhawkRumble
May 16, 2005 07:24 PM
SprintCarCowboy
Nov 3, 2004 04:30 PM
