Wont Start...please help
Old Jun 1, 2010 | 06:25 PM
Christian_man30's Avatar
Christian_man30 is an unknown quantity at this point
I rode to the movies yeterday and when I got back outside...it was pouring...1st time my HAWK has seen rain. It started & ran fine.
I rode it to work this morning...no rain...started & ran fine again. Went to go to lunch and it wont start & it just clicks when I try to start it. Got a jump start...runs fine...(ODOMETER works just fine)...(mileage & trip flickers)...(TACHOMETER goes off and on) if i pull the clutch in and rev it,...the TACH comes to life for a few seconds then back out again. Took the battery out & went to AutoZone...they tested it, and said its no longer a good battery.
1.) Could the rain have done something to cause this???
2.) Could it just be that batteries just go bad???
3.) Possibly something else???
Any input will be helpful.
Thank you in advance
Old Jun 1, 2010 | 06:37 PM
bjorn toulouse's Avatar
Destructive Tester
1.) Yes.....good idea to check the condition and cleanliness of connectors and connection points, grounds, etc.
2.) Yes.....how old is the battery?
3.) Yes.....regulator/rectifier is one of the common places to look for issues.
Rex
Old Jun 1, 2010 | 06:42 PM
CANADAVTR's Avatar
CANADAVTR is on a distinguished road
Start with a new battery (excuse the pun)....
Old Jun 1, 2010 | 06:48 PM
Its been using the EverStart from WALMART (ES12BS). Should I still go with that one. The 3 bikes ive owned have all had the EverStarts from Walmart. Im guessing good battery, or just cheapest to go with.
Old Jun 1, 2010 | 06:57 PM
Destructive Tester
Don't you mean NeverStart?
How long was it in the bike?
Rex
Old Jun 1, 2010 | 07:00 PM
No idea...i got the bike back in February and it was working great.
Old Jun 1, 2010 | 07:32 PM
Charge or replace the battery, then check voltage at idle and at 4K rpm's. If you get a low reading, suspect a faulty R/R.
Old Jun 1, 2010 | 07:54 PM
cool, thanks. thats what I figured after reading all the posts about faulty R/R's. Know anyone with an R/R from 2001 or newer that might wanna get rid of it???
Old Jun 1, 2010 | 10:50 PM
I've only got an non-finned R/R. Sorry.
Old Jun 1, 2010 | 11:22 PM
doomcookie's Avatar
doomcookie is on a distinguished road
Its battery.. a everstart in my bike those battery are not great.. Check the acid level.. If it click then it may be connection or your solenoid.. I just switch my solenoid a month ago.
Old Jul 2, 2010 | 04:42 PM
the1bolton's Avatar
the1bolton is on a distinguished road
My bike ran into a similar situation. To test the solenoid etc. I actually just connected a jumper cable to the starter + terminal (on front of bike covered in black rubber nub) and TOUCHED (not connected) the other side of the jumper cable to the battery + terminal carefully. This method only uses one wire of the jumper cable. The starting action didn't change at all from what it was doing before so it wasn't a case of good battery bad solenoid. Be prepared to pull the jumper cable off the + terminal, it welds on a little. Also, I'm not responsible if you blow yourself up.
Old Jul 3, 2010 | 03:26 PM
the1bolton's Avatar
And now that I have a new battery the bike likes to charge up the system to 16+ volts at idle. Looks like I need a new RR!
Mr.Lojo
Feb 7, 2015 02:48 PM
Goku dua
Mar 27, 2014 05:15 AM
mcadena89
Jun 3, 2009 12:04 AM
hollywood13185
Apr 20, 2009 09:16 PM
Plague325
Mar 28, 2008 07:19 PM
