my baby wont start! Please help
Old Mar 27, 2008 | 05:10 PM
Plague325's Avatar
Plague325 is on a distinguished road
Well Lets see i have a 1998 SH 996. I parked it after my ride. Bike ran well that day. Well the next day it wouldnt start! Well checked the battery and wires all good. It cranks but does not fire. Checked for spark not getting any. Possible causes are CDI, Coils, Stator its getting gas. Could it also be the kickstand switch to kill the bike thats killing it? Or whats called the angle gear? Don't know where to start. Anything else it could be. Changed the plugs already and rechecked all connection. It couldn't go bad all of a sudden could it?
Old Mar 27, 2008 | 05:16 PM
drew_c14's Avatar
Start with the simple. Is it in gear? Is the kill switch on?
Old Mar 27, 2008 | 05:18 PM
RickB's Avatar
If you have a manual look in the troubleshooting areas for some help (there is a link in the knowledge base here as well for the manual) Check the sidestand, clutch, handlebar kill switch (it happens to the best of us) etc and try to determine whats going on from there. Check both coils, one can go bad but not likely both so then check the other things mentioned including the CDI if you know someone with a comparable one but its probably something simple. good luck with it!
Old Mar 27, 2008 | 05:32 PM
filter69's Avatar
Thats Mr Dill hole to you
Im with drew kill switch. i spent 10 min the other day going what the hells wrong...and then like a bullet to the head i looked and the kill switch was on i felt pretty dumb.
Old Mar 27, 2008 | 05:39 PM
drew_c14's Avatar
we all do it...
Old Mar 27, 2008 | 06:02 PM
gboezio's Avatar
I still think that using it every time you shut the bike off is the best it becomes second nature, and make sweet backfires, try rev it and control it with the kill switch
Old Mar 28, 2008 | 05:44 AM
Reinske's Avatar
Reinske is on a distinguished road
That's why I put it away. Damn switch... Never needed it!
Old Mar 28, 2008 | 09:36 AM
If it is the kickstand you should have a big angry yellow S light shining at you.. as that dash light is on when the kickstand is down. And even then IIRC it should still start in neutral.
Old Mar 28, 2008 | 02:23 PM
434josh's Avatar
434josh is on a distinguished road
he said it cranks so that eliminates kickstand switch and kill switch since both of those simply will not let it crank.
Looks like the cdi is bad.
Old Mar 28, 2008 | 02:26 PM
ali_squidz's Avatar
mine did that and it was the ignition module thing up under the passenger seat. i think u call it a cdi. i got a used one on ebay.
it was getting spark kinda but the timing of the spark was all off.
Old Mar 28, 2008 | 06:16 PM
drew_c14's Avatar
Nope, it'll crank all day with the kill switch engaged, just won't spark.
Old Mar 28, 2008 | 07:19 PM
ali_squidz's Avatar
does it have spark or no?
Mr.Lojo
Feb 7, 2015 02:48 PM
Goku dua
Mar 27, 2014 05:15 AM
Christian_man30
Jul 3, 2010 03:26 PM
mcadena89
Jun 3, 2009 12:04 AM
hollywood13185
Apr 20, 2009 09:16 PM
