Wiring Question
Old May 28, 2010 | 12:09 AM
Grizz's Avatar
Carnivore
Grizz is on a distinguished road
Wiring Question
Ok, so I am hooking up something called a Flash2Pass unit on my Superhawk. Basically it's a system that that will open/close your garage door when you flash your high beams twice.
In the directions, it states that the 2 "quick tap" pins need to be connected to the 2 horizontal wires on the back of the headlight leaving the one vertical wire alone. It also stated that it does not matter how they are connected as the module figures out the polarity. I am trying to confirm the colors of the 2 horizontal wires prior to tapping into them and was hoping someone here would know.
Cheers,
Dean
Old May 30, 2010 | 12:13 PM
afm528's Avatar
large member
afm528 is on a distinguished road
Because I'm lazy and don't want to go look at my headlight, I checked the Flash2Pass site and found this: "Single high/low with 3 wire connector. Tap the 2 outside wires."
Does that help?
Old May 30, 2010 | 09:04 PM
Grizz's Avatar
Carnivore
I checked that as well however, the problem was, there were 2 wires on the right and one on the left. The 2 on the right were over top of each other and the one on the left was on the bottom.
Anyway, long story short, I figured it out. It's the green and the blue wires.
Old May 30, 2010 | 09:08 PM
superh1998's Avatar
I took the cheap way out and used a relay and a door opener.
The only real work to do was open the remote and solder a wire to the button.
Old May 31, 2010 | 10:09 AM
Grizz's Avatar
Carnivore
I originally thought about doing this but I still wanted to use my high beams with out sending a signal every time. Also, I don't have that "flash to pass" switch on my bike.
DavidEW
Aug 7, 2014 07:14 PM
7moore7
May 21, 2011 10:59 AM
ttocsmai
Sep 22, 2010 10:52 AM
99Hawkboy
Apr 21, 2010 02:20 PM
jhaldin
Aug 23, 2005 09:00 PM
