Time for Stage I
Old Jan 21, 2009 | 01:04 PM
  #31
FL02SupaHawk996's Avatar
Fastest Color
Very nice work Rand...I hope to be able to do that when I grow up too
If you don't mind when you have time show me a pic of you grinder setup...Tx,RC
Old Jan 21, 2009 | 01:45 PM
  #32
cliby's Avatar
very cool pictures of the finished product as well - thanks for posting those. How hard is it to learn to do a valve job? I have an 1100F (83) that apparently does respond pretty well to porting, with some standard recs for where to clean up. I even picked up a trashed head to play around with first.
Old Jan 21, 2009 | 03:14 PM
  #33
JamieDaugherty's Avatar
11.5:1 JE Pistons ordered.
I hope those work out for you. Mine didn't and JE were total dicks and wouldn't take them back. I got the royal screwing in the rear end on that deal. They are never getting another dime of mine, that's for sure. Jerks. But I'm not bitter....
Have you tried Webcams? They still have VTR cams listed in their catalog. The specs are even a touch more radical than my Yosh cams, but it's hard to say without seeing the actual lobe profile. The spec sheet numbers don't always tell the whole story. Even so, I'm sure the Webcams parts are good.
Old Jan 21, 2009 | 04:08 PM
  #34
Fastest Color
Sorry, to hear about you bad exprerience wi JE and glad you're not bitter
I did look at Webcams and that's plan "B"...look like I may have scored a set of Mori stg 1 cams...RC
Old Jan 22, 2009 | 09:23 AM
  #35
RCVTR's Avatar
I would expect the paistons to run on the high side of the skirt clearance tolerance. Honda bored these engines on the high side and JE made the pistons on the low side.
That's what I was told to expect, and it was my experience with two engines.
Here's my basic porting setup. It is two different grits of adhesive cartridge rolls, a long 1/4" mandrel and a 90 degree die grinder. Control the speed with a regulator and kee the roll moving in and out - do not dwell.
Old Jan 22, 2009 | 09:26 AM
  #36
RCVTR's Avatar
Bill,
This is what you need for cutting valve seats - and some practice.
I'm selling this set for $200. they are about $450 new. I have another set. **SOLD**
Old Jan 22, 2009 | 09:29 AM
  #37
Fastest Color
Thanks Rand, you da man!
Also, I had the JE Piston skirts coated which should help with a build up of 0.0005" on the skirts...RC
Old Jan 29, 2009 | 05:19 PM
  #38
Fastest Color
Pistons are in! No rings though...should I order a new set of factory rings or hunt down JE Piston rings to match pistons?
Attached Thumbnails Time for Stage I-01-29-09-005.jpg   Time for Stage I-01-29-09-004.jpg
Old Jan 29, 2009 | 05:44 PM
  #39
Fastest Color
These ring kits are offered on JE's website:
Top Ring Second Ring Oil Ring Part #
Axial Height/Radial Width/Type
1.5mm 0.167 IPL 1.5mm 0.167 IPL 3.0mm 0.156 IPD J612U1-3858
1.2mm 0.147 CUS 1.5mm 0.171 IPA 4.0mm 0.138 CUS XH9800
1.2mm 0.147 CUS 1.5mm 0.171 IPA 2.0mm 0.128 CUF XS9800
0.95mm 0.127 CNN none none none 2.0mm 0.106 CUF ZV9800
Old Jan 29, 2009 | 05:59 PM
  #40
Fastest Color
Nevernind on the the rings questions, JE Pistons website says to use OEM rings so I suspect they figured they couldn't make them any better
RC
Old Jan 29, 2009 | 08:26 PM
  #41
oahu hawk's Avatar
geezer
those sure are purty...
Old Jan 30, 2009 | 05:35 AM
  #42
Fastest Color
Yep, almost too purty to put in there and get them all dirty with all that carbon, but they are going in those jugs and they will scream
Old Jan 30, 2009 | 05:37 AM
  #43
zmaniv's Avatar
Just a thought I know the JE pistons are forged I dont know if the honda ones are cast or not.
forged pistons will expand more than cast untill they reach operating temp that may be why the JE's are on the lower side of the spec.
Old Jan 30, 2009 | 05:46 AM
  #44
hawxter996's Avatar
ole dirty bastard
what coatings are these?
compression ratio?
Old Jan 30, 2009 | 06:01 AM
  #45
Fastest Color
compression ratio?
Skirt,"Tuff Skirt is a JE Pistons' trademark coating that is a lubricating, anti-friction / anti-wear coating applied to the piston skirt only. Unlike our standard Skirt Coating, Tuff Skirt will not wear and is designed to withstand many different types of endurance applications, similar to those commonly found in NASCAR. Buildup is .0005" per surface and finished diameter of skirt should include the coating buildup."
Crown,"The thermal barrier crown coating is applied to the top of the piston and is designed to reflect heat into the combustion chamber, thereby increasing exhaust gas velocity and greatly improving scavenging potential. The .0015" thick coating can also assist in extending piston life by decreasing the rate of thermal transfer."
Compression = 11.5 : 1
Old Jan 30, 2009 | 07:23 AM
  #46
ff's Avatar
ff
ff is an unknown quantity at this point
how much for the pistons and coatings?
Old Jan 30, 2009 | 07:31 AM
  #47
Fastest Color
$350 USD delivered for the pistons and pins, going from 9.4:1 to 11.5:1 compression priceless
RC
Old Jan 30, 2009 | 07:50 AM
  #48
isn`t that 11.5:1? Or did you order some customs?
Old Jan 30, 2009 | 07:54 AM
  #49
Fastest Color
Opps, you are right Sir that's 11.5:1 still PRICELESS though...
Guess I got carried away there for a minute...thanks for busting my bubble
Old Jan 30, 2009 | 08:02 AM
  #50
divingindaytona's Avatar
Remember stock is BAD!
With the compression ratio of 11.5:1 are you going to have to run premium?
Old Jan 30, 2009 | 08:05 AM
  #51
Fastest Color
Yep, I figure that 93 octane will be required especially after dropping in the Moriwaki Stage 1 cams
Old Jan 30, 2009 | 08:06 AM
  #52
Didn't mean to bust any bubbles. Besides, those are slick looking slugs
Old Jan 30, 2009 | 08:17 AM
  #53
Fastest Color
Thanks! Can't wait to test them out on the ole arsedyno
RC
Old Jan 30, 2009 | 08:35 AM
  #54
autoteach's Avatar
Has anyone here installed these pistons before?? I would like to know what HP increase these would give. I imagine Tq numbers would jump considerably.
Old Jan 30, 2009 | 09:32 AM
  #55
RCVTR's Avatar
Yup.
They do.
Full Stage 1 build with all of the incremental changes gets close to 120 HP with a good full exhaust system.
Yes, rick you will use good Honda rings.
Old Jan 30, 2009 | 09:40 AM
  #56
zmaniv's Avatar
Do the stock honda rings need to be dressed to prevent ring flutter, or are they fine?
Old Jan 30, 2009 | 09:49 AM
  #57
MC Leather's Avatar
MC Leather is on a distinguished road
Be careful, in the past we have had problems with JE pistons in cylinders bored for stock pistons. Where did you find the Moriwaki cams, I'm looking for some Moriwaki parts?
Old Jan 30, 2009 | 10:14 AM
  #58
Fastest Color
Yup.
They do.
Thanks Rand! Only $38/set on Ron Ayres
RC
Old Jan 30, 2009 | 10:17 AM
  #59
Fastest Color
What kinda problems?
Old Jan 30, 2009 | 10:33 AM
  #60
RCVTR's Avatar
The ring grooves are designed for OEM rings.
