Time for Stage I
Old Aug 5, 2009 | 02:35 AM
  #301
The two engines are totally different... No parts at all are interchangeable except common bolts and such... And nope, it wont work swapping them in the frame... Haven't tried cranks, but I wouldn't imagine it possible...
Old Aug 5, 2009 | 05:16 AM
  #302
FL02SupaHawk996's Avatar
Fastest Color
Originally Posted by Just_Nick
Just curious, would it possible to stick a RC51 crank in the SH? If not, will the RC51 engine bolt into the SH frame, or are they too different?
Nick, cranks are engineered to be pretty spec-cific so I doubt there'd be any way to make the RC51 crank work in a SH block.
Also, I think wedging the RC51 motor into a SH frame would require the jaws of life and some major mounting mods, so to my knowledge that hasn't been tried either...
Old Aug 5, 2009 | 12:39 PM
  #303
JamieDaugherty's Avatar
The RC51 engine is not as different as you might think...........
Old Aug 5, 2009 | 01:25 PM
  #304
No... It's just that almost every piece is different by a fraction or two... Not to much in general, but to much to interchange parts or whole engines...
Old Aug 6, 2009 | 03:35 PM
  #305
RCVTR's Avatar
The RC51 crank lubricates the rod journals through a galley drilled in the end of the crankshaft. The Super Hawk rod journals are lubricated via cross-drilled holes on the main journals. So if the journal diameters were the same, which they are not and the stroke lengths were the same, which they are not, the crank would not swap anyway.
But they are both Honda 90 degree L-twins. Cousins, not brothers.
Old Aug 6, 2009 | 05:51 PM
  #306
Fastest Color
I figured they were kissing cousins, but not swappable...man you will prolly forget more then I'll ever learn about these motors
Old Oct 12, 2009 | 11:26 AM
  #307
Fastest Color
Sorry for the dust in your face, but I gots an update! Final assembly should start in earnest next week and with any luck I'll be on the dyno sometime in November just in time for the Winter riding season here in FL
Old Oct 12, 2009 | 05:05 PM
  #308
hawkman996's Avatar
hawkman996 is on a distinguished road
Sweet, I'm excited to see the results. After that new motor is up and running maybe we could get some FL members together for a ride?!
Old Oct 13, 2009 | 05:15 AM
  #309
Fastest Color
We need to for sure! You going to Daytona for Biketober fest this weekend?
Old Oct 13, 2009 | 06:38 AM
  #310
Can`t wait to see some results from your build Rick. Just remember to that the output will go up a bit once everything is properly seated. Should make for an exciting ride!
Old Oct 13, 2009 | 06:43 AM
  #311
Fastest Color
Yep, I'm looking forward to never wearing out a front tire again cuz it wont be touching the road through the first 3 gears
Old Oct 19, 2009 | 02:59 PM
  #312
RCVTR's Avatar
Man, it sure takes you guys a long time to build an engine...
Not that I have a lot of room to talk. I did 15 minutes more riding this year than the last 4 years combined, though.
I guess I didn't tell you about the leak in my fuel tank, before my last track day that didn't happen. I didn't want to ride it in primer anyway...
Old Oct 20, 2009 | 04:49 AM
  #313
Fastest Color
Yep, I couldda built it at least twice by now, but I knew the score when I took it to him cuz he had 3 in front of mine already...no biggie since it's a donor motor I'm still ridin anyway
Sorry to hear about your leak dude, but I can't blame you for not wanting to show up at the track in primer either. Prep it good so the paint is smooth for the next owner...LOL!
Old Oct 20, 2009 | 06:08 AM
  #314
AdamK's Avatar
Always Learning
Impressive
OK I feel stupid just reading this one. OK for all the "stuff" your are doing with this motor swap and stage 1,2,3, and blah blah blah, What is that dong for the performance of the bike? The reason I ask is cause it seems like a BOAT LOAD of work and a crap ton of money. Or is that my stupidity again?
I just bought a 98 with 15k in really good condition but has a smal tic tic tic and think it might be the valves that are out of adjustment, and also at idle, it will drop *** and cachunk stall. (kinda what it sounds like) My problem is I have no clue where to start. You guys are swapping out motors like it is a weekend thing.
Just impressed with the knowledge and wish I had neighbors like that.
  #315
AdamK's Avatar
Always Learning
Impressive
Old Oct 20, 2009 | 06:23 AM
  #316
Fastest Color
It's a labor of love and an extra 10-20 Hp helps! I suggest you do a search for CCTs replacement to help your ticking cuz you'll be due for a valve check at 17K miles and it's an easy swap to put in manual CCTs while you're in there checkin valve clearances...
Old Oct 20, 2009 | 06:28 AM
  #317
AdamK's Avatar
Always Learning
Huh... OK apparently you thought I was joking with my statement of stupidity. So will adjusting my valves (other than the local Honda dealer) be a challenge for someone um... as challenged as I? I'm not a complete idiot so as long as it is not that difficult I could give it a shot. Just my first "street bike" so a little new with working on them.
And CCT's? Huh?
Old Oct 20, 2009 | 07:32 AM
  #318
AdamK's Avatar
Always Learning
What are CCT's and how easy are they to replace? Find out if mine are stock? Anything?
Old Oct 20, 2009 | 08:47 AM
  #319
Erik S.'s Avatar
Adam,
We're trying to be on a little nicer streak to the new guys, ya know, not flame them so hard, so senior members won't whine.
First, there is a lot of knowledge in the KNOWLEDGE BASE found here: https://www.superhawkforum.com/forum...splay.php?f=40
Next, the "Search" function is wonderful, even if you don't know what a CCT is, it will find plenty of threads on it, this is the result of a "search" for CCT:
https://www.superhawkforum.com/forum...earchid=484270
Finally, CCTs are Cam Chain Tensioners. Thread in the KNOWLEDGE BASE is here:
Hopefully, you don't suffer from being computer illiterate as well as not being mechanically inclined.
Old Oct 20, 2009 | 08:59 AM
  #320
The cachunk thing is likely the carbs that are out of sync...
There is a thread around here somewhere where the steps in replacing the CCT's are layed out and with pics... go seach "Cam Chain Tensioner replacement" and you'll find it... If it looks scary, go to a shop... If not ask questions and we will do our best to help...
Old Oct 20, 2009 | 09:15 AM
  #321
AdamK's Avatar
Always Learning
Originally Posted by Erik S.
Adam,
um... wow... I guess looking for the word "search" would have been a good place to start. My bad.
No I am not hopeless that is for sure and I can't thank you enough for not drilling me (that goes to all). The knowledge here is incredible and I am sure with some wrenching I may be able to at least understand some of these forums a little better.
SO!!! With that being said thank you for the links above I will definately do some homework and see if I can't learn me a thing or two.
Old Oct 20, 2009 | 09:42 AM
  #322
Erik S.'s Avatar
Not a problem, I prefer to provide and lambast equally and at the same time.
It will take a while. You'll figure out what all the jargon means, like PWNT thread. Read, relax and enjoy. You've found a wonderful machine, just like us.
Now on the other hand, don't be afraid to ask. Sometimes the information is so obscure, that even a search or series of searches fails to bring to light what you are looking for, and it might be that someone knows exactly where it is.
Welcome to the club, welcome to the initiation period.
Old Oct 21, 2009 | 09:40 AM
  #323
Bearshawk's Avatar
agreed with adamk i am a college student who loves wrenchin but damn you guys are good, its incredible how much i have learned about my new SH just from READING the threads and looking at the pictures a thousand thumbs up
Old Mar 24, 2010 | 07:59 AM
  #324
Fastest Color
It's alive!
Well not exactly, but this project has been resurrected! Sorry for the dust in the face...
Yesterday I retrieve all the sweet stage 1 motor parts from my tuner who I've been waiting on for what seems like a year now to build this motor up for me
I was trying to avoid doing this myself, but looks like the buck stops here!
Stay tuned
Old Mar 24, 2010 | 08:26 AM
  #325
Syclone's Avatar
Boosted
Good luck, with a little patience you'll have it all together in no time.
Old Mar 24, 2010 | 08:32 AM
  #326
Fastest Color
Thanks! The only thing I'm worried about is degreeing in the Morwi cams
Old Mar 24, 2010 | 08:43 AM
  #327
Good luck Rick. Take your time, double-check everything and you should do fine
Old Mar 24, 2010 | 08:45 AM
  #328
Fastest Color
You may yet get yours built before mine
Old Mar 24, 2010 | 09:05 AM
  #329
Don`t think that will happen as mine will be rebuilt at the very earliest late this Fall but more likely next Fall. Would love to get it done now but I can`t really justify the cost at the moment (especially considering I have just forked out for a bunch of new, more minor mods.... again!!!!! OCMB again!!!)
Old Mar 24, 2010 | 10:29 AM
  #330
This might help if you haven't seen it...... http://www.muzzys.com/articles/lobe_centers.html
