Synchronizing Carbs after rejetting
Old Mar 23, 2006 | 01:09 PM
collectiv's Avatar
collectiv
Hello,
I believe that Honda recommends synchronizing the carbs every 6 months. My question is that if you install a jet kit, should you synchronize them. I know that to syncrhronize them, you have to @ some point turn the fuel mixture screw on one of them. But....isn't that one of the steps you have to do also while jetting to make it run smoother? Wouldn't doing this during the synchronizing of the carbs kinda affect the jetting again?
I maybe totally off but......I could use some feedback,
Eddie
Old Mar 23, 2006 | 02:27 PM
divingindaytona's Avatar
Remember stock is BAD!
Re: Synchronizing Carbs after rejetting
Yes
Sync'ing is balancing of the two carbs. You have two huge carbs that are sucking down air and fuel, they need to pull in the same amount. Otherwise one cyl is getting a different amount than the other.
After you put in a jet kit you need to sync the casrbs. Otherwise you arn't getting the most for your $, and the best performance.
Old Mar 23, 2006 | 02:41 PM
EngineNoO9's Avatar
basically everytime you mess with the carbs (other then adjusting idle) you should re-synch... I haven't yet... but probably should
Old Mar 23, 2006 | 02:57 PM
collectiv's Avatar
collectiv
so by synchronizing the carbs after rejetting, you essentially have to adjust the same fuel mixture screw which you used to smooth'n out the ride after re-jetting right? With that said, wouldn't that mess up the jetting adjustment by doing this?
I'm not sure if i'm saying it correctly or not, LOL.
Eddie
Old Mar 23, 2006 | 03:16 PM
collectiv's Avatar
collectiv
ahaha, disregard my previous post, i actually checked the manual and it isn't the fuel mixture screw that you adjust when syncrhronizing the carbs. My bad.
Old Mar 25, 2006 | 07:28 AM
xxxrated's Avatar
xxxrated
have fun balancing the carbs unless you have hands the size of a new born baby, is about as much fun as sticking hot needles in your eyes
Old Mar 27, 2006 | 08:15 AM
Loco's Avatar
Loco
Syncing the carbs does NOT use that air-fuel mixture adjustment **** that's on the bottom of the carb bowls. That **** is used to seat your needles when you re-jet. The carb-synching screw is the one attached to the exchange rod that runs between the carbs. It would be literally impossible to reach that misture adjustment screw with the bike running, so don't worry about that one. I believe it is a #7 socket that requires a universal joint and an extension on your socket wrench. The hardest part, actually, is attaching the vacuum tubes.
Old Mar 27, 2006 | 04:48 PM
xxxrated's Avatar
xxxrated
thats the part im on about, found a way round the rear vacuum hose but the front is beyond a mission
Old Mar 28, 2006 | 05:01 PM
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
Attaching the vacuum tubes isn't that difficult if you leave the brass 'nipple' installed on the front cylinder, and run a short tube out and plug it. Hell with that install nipple/balance/reinstall plug BS... I also installed a T fitting in the line off the rear port, so all I've got to do is uncap and hook up the gauges!
natewill
Mar 15, 2012 03:49 PM
Shawker03
Apr 17, 2008 07:45 AM
reaper
Oct 26, 2007 05:25 AM
azhawk1
Aug 2, 2007 03:04 PM
extrmski
Jan 16, 2005 07:40 PM
