Stupid brake question
Old Nov 20, 2013 | 08:16 PM
So I am mounting cbr600rr brakes onto 05 zx10 forks. Which bolts do I use? (caliper ones or fork ones). The cbr bolts are 10x57, the zx bolts are 10x60.
Which ones and why. Only concern is whether there is enuff depth in fork thead right?
Old Nov 20, 2013 | 09:16 PM
That is correct, I'm not sure how it's setup with the ZX caliper mounts, but you also need to see that the bolts don't penetrate too far and touching the rotors or anything else in the way of the bolts, once you install them, spin the wheel in the air just to make sure all is clear. If you had some pictures it would be nice to see how it's setup.
Oh yea, there are no stupid questions when it comes to safety
Old Nov 20, 2013 | 11:08 PM
Super Hawk Pro's Avatar
Super Hawk Pro is on a distinguished road
The only stupid safety questions are the ones that are NOT asked.
Old Nov 21, 2013 | 05:44 AM
As you`re dealing with radial brakes and the bolts are being screwed into aluminum (bottom of fork leg), I say use the longest ones possible that do not bottom out, thereby ensuring maximum grip and penetration....
Old Nov 21, 2013 | 05:45 AM
But these are radial mount calpers so the mounting is parallel to the rotors (will never touch). Thats why its not so obvious the answer.
Old Nov 21, 2013 | 06:05 AM
Same answer you already had above...
Use the longer bolts if they will thread though the caliper mount and into the fork leg fully.. if not, use the shorter
For steel, a basic rule of thumb for thread engagement length for a screw in a tapped hole should be 1.5 the Diameter, where Diameter is the major diameter of the screw.
I've also seen it suggested engagement length of 1.0D for steel, 1.5D for cast iron, and 2.0D for aluminum.
I try for 1.5D in any steel and use 2.0D in any non ferrous metal.
Old Nov 21, 2013 | 03:30 PM
I am often left wondering why I even bother........
Old Nov 21, 2013 | 03:53 PM
insulinboy's Avatar
measure the caliper where the bolt goes through with a micrometer if you have one (if not they are cheap enough, its a priceless tool Digital Calipers - Save on these 6 Inch Digital Calipers) if the ZX and the CBR calipers are the same size where the bolt goes through use the longer bolt, if the CBR is a few mm narrower than the ZX use the shorter bolt.
Old Nov 21, 2013 | 09:29 PM
Yeah, I am using the longer bolt, but dont have all components of each to do any measuring. Mikstr, we typed our entries simultaneously(look at the times), I was refering to NHSH about hitting the rotors.
I cant know the caliper thickness difference but hope 3mm cant make it bottom.
Old Jan 1, 2014 | 11:46 AM
Aquasnake's Avatar
Screw one each of the bolts in, finger tight, until they bottom out. Measure how much is sticking out, from bottom of bolt head to mounting surface. Measure thickness of caliper mounting, with spacers if needed. Choice should then be obvious. As has been said before, use the longest bolts that you have that will not bottom out when calipers are mounted and bolts properly torqued to specs.
t-dogg
Jun 2, 2010 01:04 PM
dshakes
Apr 26, 2010 05:34 PM
The Hawk Guy
Jan 19, 2007 03:11 AM
seattlesucks
Jun 28, 2006 12:35 PM
EngineNoO9
Nov 11, 2005 09:16 PM
