SPRING RATE'S
Old 11-06-2012, 07:42 AM
ukbiker.me
seb421's Avatar
seb421 is on a distinguished road
Arrow SPRING RATE'S
REAR SHOCK SPRINGS
i came about this trying to find out about my shock, i thought i had been sold a WP shock that was for a rider 170-175 kg in weight as that was what was stamped on the spring 170-175, thankfully Al pointed out to me that i was incorrect in thinking it was kg rating it was infact the Newton Force rating of the spring, so to anyone that has a got a shock second hand and doesn't know what spring is on it this may be of some use?
Springs may be marked up with a lb/in force number or a N/mm number
RT - Digital Product Search
Recommended Shock Spring Rate (for me 14 stone): 17.3 kg/mm (use closest available)
You can get the Newton force by multiplying the Mass and the Acceleration. F = m.a,
So in this case the Acceleration is the Gravity which is 9.8 m/s. and the Mass is the Spring rate given
The answer is F = 17.3kg X 9.8m/s = 169.54N
So ideal spring for me Solo would be 170N so very happy with the 170-175 spring,
To get a kg rate of a spring for a listed Newton force simply divide the Newton Force by Gravity
So
175N/mm / 9.8m/s = 17.8kg/mm
170N/mm / 9.8m/s = 17.3kg/mm
So what is a Spring Rate??? A Spring rate is the number of kg or Newton needed to move the spring by 1 mm (or inch if you use lb rating).
Here are some pre worked out spring rates for the rear shock for road use on a Firestorm
To work out what spring rate suits what rider weight you have to then factor in the shock linkage ratio, the weight of the bike, the weight distribution of the bike and the type of riding. Then you add the rider weight (in full riding gear). These are results calculated by the Racetech site, i have added the N/mm and lb/in data using conversion rates
Stock Rear Shock Spring Rate: 16.4 kg/mm = 160.8 N/mm = 918.3 lb/in
9 stones = 15.55 kg/mm = 152.3 N/mm = 870.7 lb/in
10 = 15.9 kg/mm = 155.8 N/mm = 890.3 lb/in
11 = 16.25 kg/mm = 159.2 N/mm = 909.9 lb/in
12 = 16.6 kg/mm = 162.8 N/mm = 929.5 lb/in
13 = 16.95 kg/mm = 166.1 N/mm = 949.1 lb/in
14 = 17.3 kg/mm = 169.5 N/mm = 968.7 lb/in
15 = 17.65 kg/mm = 172. 9N/mm = 988.3 lb/in
16 = 18 kg/mm = 176.4 N/mm = 1007.5 lb/in
17 = 18.35 kg/mm = 179.8 N/mm = 1027.5 lb/in
18 = 18.7 kg/mm = 183.2 N/mm = 1047.1 lb/in
19 = 19.05 kg/mm = 186.6 N/mm = 1066.7 lb/in
20 = 19.4 kg/mm = 190.1 N/mm = 1086.3 lb/in
FRONT FORK SPRINGS
(Standard Firestorm Forks)
Stock Fork Spring Rate: .585 kg/mm(stock) Very Soft and undersprung
9 Stone = 0.791 kg/mm = 7.75 N/mm = 44.29 lb/in
10 = 0.812 kg/mm = 7.96 N/mm = 45.46 lb/in
11 = 0.833 kg/mm = 8.16 N/mm = 46.64 lb/in
12 = 0.854 kg/mm = 8.37 N/mm = 47.82 lb/in
13 = 0.875 kg/mm = 8.58 N/mm = 48.99 lb/in
14 = 0.896 kg/mm = 8.78 N/mm = 50.17 lb/in
15 = 0.917 kg/mm = 8.99 N/mm = 51.34 lb/in
16 = 0.938 kg/mm = 9.19 N/mm = 52.52 lb/in
17 = 0.959 kg/mm = 9.40 N/mm = 53.70 lb/in
18 = 0.98 kg/mm = 9.61 N/mm = 54.87 lb/in
19 = 1.001 kg/mm = 9.81 N/mm = 56.05 lb/in
20 = 1.022 kg/mm = 10.02 N/mm = 57.22 lb/in
I will also work out the rates for CBR 929 / 954 forks fitted to a Storm and fill in shortly
Rider Weights (approx)
Code:
9 Stone
57 Kg
126 lbs
10 Stone
63 kg
140 lbs
11 Stone
69 Kg
154 lbs
12 Stone
76 Kg
168 lbs
13 Stone
82 Kg
182 lbs
14 Stone
89 Kg
196 lbs
15 Stone
95 Kg
210 lbs
16 Stone
101 Kg
224 lbs
17 Stone
107 Kg
238 lbs
18 Stone
114 Kg
252 lbs
19 Stone
120 Kg
266 lbs
20 Stone
127 Kg
280 lbs
*Thanks to AMCQ46 for helping me with this as i was about to get rid of this shock had he not informed me of how springs are marked up
seb421 is offline
smokinjoe73
03-22-2010 08:31 PM
jason54
01-19-2010 04:44 PM
RuthlessButcher
07-07-2009 04:08 PM
speedkelly@aol.com
07-18-2007 06:00 PM
roadrun_fr
07-20-2005 02:37 PM
Quick Reply: SPRING RATE'S
