Shifter Fix
Old Dec 3, 2007 | 08:17 PM
Hotbrakes's Avatar
Shifter Fix
So I laid her down the other day thanks to cold roasted race take offs and cold pavement at walking speed. It was a pretty sweet spin that I almost maintained control of except it wouldn't stop so I set her down easy but it broke the **** off my shifter. I'm probably just gonna drill it, tap it, and put a bolt in it with the stock rubber piece. Anybody else try this fix?
Old Dec 3, 2007 | 08:58 PM
killer5280's Avatar
I did it, but I lost the stock rubber piece and just used a piece of rubber tubing. Been this way about 8 months and works just fine.
Old Dec 3, 2007 | 09:19 PM
Hotbrakes's Avatar
Sweet...looks good.
Old Dec 4, 2007 | 06:27 AM
RickB's Avatar
Not bad... as long as it works!
Old Dec 4, 2007 | 06:44 AM
autoteach's Avatar
I've done this as well, with the stock rubber piece. It works (better then buying new).
Old Dec 4, 2007 | 08:47 AM
FL02SupaHawk996's Avatar
Fastest Color
Necessity is the mother of invention or something like that...Looks as good as new and probably stronger too
Old Dec 4, 2007 | 08:52 AM
killer5280's Avatar
It should work a long time. It's actually of much higher quality than the stock piece of pot metal.
Old Dec 4, 2007 | 09:13 AM
RickB's Avatar
agreed... it should be better than stock and hold up very well.
Old Dec 4, 2007 | 09:55 AM
996's Avatar
996
v-twin4tmfw
996 is on a distinguished road
I did this too while I was waiting for the replacement lever. It worked good. The stock item is somewhat expensive for what you get, but the bolt trick looks a little ghetto imho.
Old Dec 4, 2007 | 09:57 AM
autoteach's Avatar
The other thing that I worry about is how strong it is. The origianl breaks off real nice like when it contacts the ground, the bolt won't. How much stuff is it going to ruin? I hope I don't have to find out.
Old Dec 4, 2007 | 10:05 AM
killer5280's Avatar
The look of it doesn't bother me one bit, especially considering the price of a new lever. Nobody knows but me anyway.
Old Dec 8, 2007 | 09:39 AM
996's Avatar
996
v-twin4tmfw
We know !
Old Dec 8, 2007 | 03:19 PM
happytrack44's Avatar
WERA #44
I used an f3 shifter for a while waiting to find a good hawk unit. It is steel, a little longer, and the pivot is much wider than the hawk, so you have to use the f3 bolt.
I have found that there were 2 different hawk shifters, one with a steel adjusting rod, and one with a nice aluminum adjusting rod. I don't know which years are which, but the aluminum rig looks really sharp.
I have an extra complete spare steel rod set.
Old Dec 8, 2007 | 10:27 PM
Reinske's Avatar
Reinske is on a distinguished road
Just my thought, too. If your bikes lays down on the left side again, this one won't break. But it might waste the footrest... A bolt with 215kg on it... has got a force! You better don't try...
Old Dec 9, 2007 | 02:20 AM
If a steel higher equivalent grade bolt is used (I would use a stainless steel button head cap screw), grind a notch partially through it near where it enters the shifter lever arm on its bottom side so it snaps off there in a crash; similar to what is done with clutch and hand brake levers.
Old Dec 10, 2007 | 06:33 PM
I rode with a bolt as a shifter **** for about 10k miles. Never knew the difference.
viperkillertt
Jul 30, 2010 08:27 PM
SillyHawk
Sep 5, 2006 07:38 AM
99Hawkboy
Aug 14, 2006 07:03 PM
CNI Dawg
Mar 4, 2006 01:26 PM
Jay C
Nov 18, 2005 02:40 PM
