Sargent seat - solo cowl
Old Dec 31, 2004 | 04:36 PM
pickle.of.doom's Avatar
pickle.of.doom
Mine seems to fit snugly on my Sargent, at worst it may be a little lopsided on there. I know its a pain to get the tabs to snap in place, but thats the only thing I have noticed about it.
Old Jan 3, 2005 | 05:24 PM
Make sure that it is on correctly. The two side tabs have holes for locator pins and the large tab in the rear goes under the seat.
Old Jan 4, 2005 | 11:06 AM
NOrrTH's Avatar
Re: Sargent seat - solo cowl
Oh great
My Sargent should be here any day. I love my rear seat cowl. I'll be PO'd if it doesn't fit like their website says it should.
Old Jan 6, 2005 | 03:22 PM
NOrrTH's Avatar
I put mine on day before yesterday and it was a bit of a battle. It fits more than snugly and I had to pound on the rear of the seat to get the lock to snap into place. Initially it would click in and lock but wouldn't sit down flush unless I gave it a good rap. Hopefully it will losen up with time as the foam gets compressed against the tank.
Putting the solo rear cowl over the seat was a battle. Getting the cowl's tabs around the "L" hooks was a bitch. Sargent recommends trimming them so you dont have to stretch them out so far.
Bottom line is that both are in place and looking awesome. Its firmer than the stock seat. I'd get a sore *** from the stock one after a couple of hours on it. For $400 cdn I'll be pissed if it still is after this.
Old Jan 6, 2005 | 03:54 PM
faz's Avatar
faz
faz
thanks for the update.
after riding an F4i for over a year, my *** finds superhawks OEM seat both soft and pleasing!
Old Jan 10, 2005 | 04:33 AM
Rollingalong's Avatar
Rollingalong
I did the tab trim thing and was tempted to put some axle grease on the thing to help . All in all the fit is good and feel is even better .
The Sargent makes life A-OK .
Old Jan 16, 2005 | 06:37 PM
HotStreetVTR's Avatar
HotStreetVTR
"SuperChicken III" came from its previous owner/abuser with both a Sargent seat and a seat cowling, and the previous owner/abuser both cracked the seat cowling (top-front-center) and broke off its right and left tabs (apparently to make things easier for removing and re-installing the cowling).
I plan to replace the cracked cowling when I put the finishing touches on SuperChicken III , so I would like to know if the left and right tabs of the OEM cowling must be trimmed slightly to prevent them from interfering with the seat-locking mechanism on the Sargent. Do you think that the previous owner/abuser trimmed the tabs originally and the tabs broke, through time, because he trimmed them a little too closely to the center holes? Or, was he off-base altogether in even attempting to trim the tabs (will they work without being trimmed)?
Thanks for your help,
--HotStreetVTR
Old Jan 17, 2005 | 10:25 AM
NOrrTH's Avatar
I suggest the centre of the cowl cracked trying to get the tabs around the "L" brackets; then he trimmed the tabs Its a big stretch for the cowl to get around them. Even with the tabs trimmed, imo, its pretty hard on the cowl taking it on and off, much harder compared to the stock seat. No doubt the cowl tabs broke through use.
Definitely trim the tabs or you risk breaking the cowl.
Old Jan 17, 2005 | 05:38 PM
HotStreetVTR
I'll bet that you're right about the crack at top-front-center originating during removal of the cowling and about him having later broken-off the tabs.
After I replace the cowling with a new one, I will be sure to both trim the tabs slightly and enlarge the eyelet holes to prevent over-stressing of the new cowling. Also, the rear pad on my Sargent seat is bright red and would look goofy--clownish--in contrast to the bike's Kandy Blue, so I will be removing the cowling only if I need to accomodate a passenger (a rare occasion).
Thanks for the insightful observation.
cheers,
--HotStreetVTR
kardiac996
Jul 7, 2012 08:05 PM
Roundboy
Dec 30, 2008 12:26 PM
scarface
Sep 24, 2008 01:13 PM
Randman
Feb 19, 2008 12:19 PM
blackvtr
Apr 8, 2007 12:34 PM
