Replacement Front Rotor Bolts?
Old Mar 28, 2008 | 02:12 PM
Moto Man's Avatar
Duc Hawk
I have been looking all over for replacement bolts for my new rotors as the service manual says you should replace the bolts when remounting rotors.
All the bolts I can find with the same thead size have a smaller head than the stock ones. I bought some that are stainless steel and should be stronger than the old factory ones but like I said have a smaller shoulder (head) than stock. I tried reusing the old ones and sheared off the head of the bolt only using 15lbs of torque!!!? That is why I want better metal than stock.
My question is have any of you used bolts other than the factory rotor bolts?
Old Mar 28, 2008 | 07:10 PM
Gregw's Avatar
Hi Moto,
I could be completely wrong, but I think they are designed as single use only. I’ve run across shear bolts (that’s their name) on the brakes for my truck. Probably a safety issue using old stretched bolts. I’d recommend getting the stockers. YMMV
Old Mar 28, 2008 | 08:46 PM
Moto Man's Avatar
Duc Hawk
Thanks for the input Greg. Think I might have to order some stockers from hondaparts-direct.com but these TI bolts from Knee draggers look intresting...
http://www.kneedraggers.com/details/..._--613193.html
But at $90+ for the front rotor set it's a bit steep. I was hoping for something better than stock but not quite TI grade. Anyone know of "mid grade" bolts?
Old Mar 29, 2008 | 08:35 AM
I've always reused my rotor bolts. The torque specification is only 14 ft-lbs. That is far from a torque-to-yield bolt. They are installed with threadlock, so upon installation I recommend the same.
Old Mar 31, 2008 | 12:08 PM
Moto Man's Avatar
Duc Hawk
Thanks Greg! The bike came from the coast, so the bolts are a bit rusted from the salt air. That being the case I would rather replace them. Still can't belive one extra pound of torque sheared the head off! But then again the rotors were warped a bit and so the bolt could have been compromised through some rapid cooling like I suspect the rotors were. It could have been a post ride hose down by the previous owner I think.
I ened up ordering a new set of stockers from honda parts direct. Anyhow it's good to know you've been fine with reusing them in case I need to reuse the new ones in the future.
zagger1586
Jun 14, 2011 01:59 AM
rhorsley
Jul 22, 2009 03:12 PM
ali_squidz
Mar 31, 2007 06:42 PM
EngineNoO9
Nov 25, 2006 08:15 PM
RonVTR
Aug 28, 2006 09:11 PM
