rear shock spacer?
Old Oct 24, 2006 | 06:27 PM
superdave's Avatar
superdave is on a distinguished road
rear shock spacer?
has anyone used a rear shock spacer? Does anybody know if a firestorm rear shock spacer will fit a superhawk?
Old Oct 24, 2006 | 06:33 PM
superhawk22's Avatar
I have an adjustable shock so no I haven't used it but Firestorm is just the Euro name for the Superhawk.
Old Oct 24, 2006 | 07:58 PM
I (and many others) have shock spacers in place and they work well. The only caveat (and this comes straight from a very knowledgeable source, Roger Ditchfield at Revolution Racing in the UK, a real VTR guru) is that it is NOT to be used with a stock front-end set-up (ie. unmodified forks) as it may cause the motorcycle to become dangerously unstable.
Old Oct 24, 2006 | 08:02 PM
superdave's Avatar
thanks for that info. i have a stock front end.
Old Oct 25, 2006 | 12:39 AM
RonVTR's Avatar
RonVTR
Ok I'm going to through in my 2 cents... Before I got my Penske I used a 3mm spacer between the frame and the shock mount. It quickened the stearing slightly in a good way. Did this for two years with never a shake, shimmy or wobble. I also had stock front forks.
Old Oct 25, 2006 | 11:45 AM
RPV-Hawk's Avatar
RPV-Hawk is on a distinguished road
I've been using a 5mm spacer (home made) for the last 2 years. Never had a problem. I use a 15mm spacer (home made) when I do track days. Yes, turn in is improved quite a bit, but not what I would consider "instability". You do need to watch for the shock linkage dogbone contacting the exhaust pipe at full (or near full) compression. If you keep an eye on the pipe and the dogbone and look for signs of contact (scuffing/scratching). If you see that, take 2-3mm out of your washer stack until the problem stops.
I also lower the triple clamps about 40mm for track days as well. The combination of the two works for me. Try/experiment at your own risk!
Old Oct 25, 2006 | 05:04 PM
JamieDaugherty's Avatar
I've been running a 6mm spacer with a stock front end for almost 7 years now. 1000's of racetrack miles without a steering damper (I've never needed it on the VTR) speaks to the fact that's A-OK with the stock front.
Old Oct 26, 2006 | 12:02 AM
killer5280's Avatar
I'll just chime in here and say that before I installed RaceTech springs I had a 5-6 mm spacer (4 fender washers, I believe) with the stock front end with no scariness.
Old Oct 27, 2006 | 04:39 AM
shayne's Avatar
Ditto.
I know a few riders with a shock spacer and standard forks, and no complaints from anyone. And some of this lot ride VERY fast.
Wagonryan
Sep 2, 2013 04:00 PM
Quin
Feb 27, 2012 07:43 PM
Storm
Jul 2, 2010 11:45 AM
smack doogle
Oct 4, 2008 12:31 PM
CNI Dawg
Nov 13, 2005 05:47 PM
