Race Tech Springs Installed
Old Feb 22, 2008 | 05:56 PM
oahu hawk's Avatar
geezer
Per recommendations from the forum, I had Race Tech .85s installed today.
Great improvement in the ride and much less dive under braking.
A side benefit has manifested itself also, the front is a smidge higher than before, which has relieved some of the pressure on my old arthritic hands...
Old Feb 22, 2008 | 05:58 PM
drew_c14's Avatar
Good stuff. Did you replace just the springs, or fluid as well?
Old Feb 22, 2008 | 06:08 PM
oahu hawk's Avatar
geezer
Fluid replaced also, 10w fork oil I believe...
Old Feb 22, 2008 | 06:09 PM
drew_c14's Avatar
Cool. I've always been a believer that quality fluid made a difference almost as big as the springs themselves.
Old Feb 23, 2008 | 01:07 PM
nnjhawk02's Avatar
Yep Racetechs R good, but Ohlins on rear R nicer
I did both - w/ .85 - I'm thinking U weigh about 180 to 195?
Old Feb 23, 2008 | 01:51 PM
oahu hawk's Avatar
geezer
I probably weigh 175-180 with gear on...
Old Feb 23, 2008 | 03:01 PM
With RT .95 and PVC preload spacers at about 3.5" + 2 RT washers top and one below the spacer. I like Silolene's synthetic fluid. Started with 15 wt cut down to about 12 wt with Mobil 1 syn ATF. Fluid level for my 225+# w/gear is about 5.25" from fluid level to top of vertical tubes, springs out and forks bottomed. I run rebound about 1/8" from full in and preload at 3~4 lines showing. Eventually I'm going to have greg do his magic on the forks. A Penske 2-way shock with ride height works just about perfect for the street. The Conti Sport Attack front & Road Attack rear seem like a good match.
blamecanada
Jan 18, 2012 06:44 PM
RCVTR
Oct 28, 2007 06:37 PM
redman
Aug 25, 2007 09:02 AM
102dals
Nov 27, 2006 02:46 PM
MOTOBENSON
Mar 22, 2005 07:20 AM
