Quick pair question so i can ride
Old Dec 29, 2012 | 11:15 AM
0317Hawk's Avatar
0317Hawk is on a distinguished road
Just performed pair removal and want to make sure I am supposed to cap every vent line connecting to the bottom of the air box. Also, can I cap where the front breather hose connects to the front of the engine at what I believe is the cylinder head cover? There is air coming out of that hose and also maybe a little oil or lubricant of some sort. Thanks
Old Dec 29, 2012 | 09:01 PM
Squid's Avatar
The front nipples comming off of the valve covers need to be capped. Everything on the airbox minus the 2 breather hoses can be capped, If I remeber correctly. Pretty much everything that you had removed that has an opening needs to be capped and plugged. There is a write up in here. Just mske sure you follow it word for word, and down load the shop manual for the link on here, its a PDF. I didnt follow it word for word and ended up capping a nipple on the carbs that allowed a vaccume to occure and fuel would flow out of the carbs when I shut it down after a 5 second start.
0317Hawk
Dec 29, 2012 01:39 PM
98VTRrider
Dec 20, 2011 12:33 PM
uchi
Nov 2, 2009 06:03 PM
E.Marquez
Dec 31, 2008 01:44 PM
roadrun_fr
Aug 3, 2005 04:55 PM
