PENSKE SHOCK SPRING RATE QUERY
Old Mar 11, 2010 | 12:03 PM
Can some tech wiz guy let me know the spring rate I need on a VTR penske shock for a 190lb rider & sometimes 2 up street touring? No racetrack shenanigans. I guess I need lb/in & kg/mm
Old Mar 11, 2010 | 01:09 PM
greyhawk's Avatar
greyhawk is on a distinguished road
shock
just call penske directly they will tell you your spring rate.
Old Mar 22, 2010 | 10:35 AM
RacerX820's Avatar
RacerX820 is on a distinguished road
I just got my hands on a shock of a 599 for free!!!! and it comes with a 1Kg spring rate so even though it Penske calls for a lower spring rate I am going to see how it goes. Will let you know.
Old Mar 22, 2010 | 11:07 AM
You might have to send it to penske or a local suspension shop to have it reconfigured to fit in a SH but penske shocks are modular so it should be no big problem to get it to fit. Also on the spring rate 1kg? Maybe 1000lbs\in but a Sh should use between a 16kg\mm -18Kg\mm for American sized riders...
Old Mar 22, 2010 | 12:33 PM
trinc's Avatar
mine has the 1000 spring... my preload is almost all out but it is set for the track & i'm at 180ish lbs. regular street i may opt for the 950...
tim
Old Mar 22, 2010 | 01:30 PM
RacerX820's Avatar
The 1000 lb shock would be a 17.9 kg/mm shock spring. This is just on the high side of the acceptable range. I am going to get the Superhawk ends put on and back the preload all the way out and see how it feels.
Also trinc what would you recomend for a front fork set up? I know with the penske the stock fron is going to be way mis-matched and the chassi will probably be all over the place.
Old Mar 22, 2010 | 02:18 PM
residentg's Avatar
I am having a 17.32 spring installed on my Ohlins - that is for 200lbs street rider or 170lbs "agressive" rider. This is based on the recommendation of the Ohlins rep that I spoke with. The racetech site echoed this. 17.9 is a bit high, but not unreasonable so. The stock SH shock has a 16.40 spring. Try it out before you spend any money.
As for the forks, I am running .90 racetech springs with 7wt oil, 135mm level. At some point I will have them revalved. The.90 front matches the 17.32 rear.
JB
Old Mar 22, 2010 | 03:40 PM
JamieDaugherty's Avatar
I calculate a 959lb/in spring rate for a 190lb rider. Since you can only get springs in 50lb/in increments, I would normally suggest a 950lb/in rate for you. If you are really aggressive or run the bike on the track a lot I would go up to a 1000lb/in part.
For what it's worth, Penske has the following recommended spring rates by weight:
160-190lb = 950lb/in
190-225lb = 1000lb/in
You are right on the border, but I would still go with the 950lb/in.
Old Mar 22, 2010 | 08:31 PM
bjorn toulouse's Avatar
Destructive Tester
Can some tech wiz guy let me know the spring rate I need on a VTR penske shock.......
Check out the Penske site: http://www.penskeshocks.com/Motorcycle-Spring_Chart.php
Rex
roncris
Apr 1, 2012 09:03 AM
jason54
Jan 19, 2010 04:44 PM
RuthlessButcher
Jul 7, 2009 04:08 PM
speedkelly@aol.com
Jul 18, 2007 06:00 PM
roadrun_fr
Jul 20, 2005 02:37 PM
