new sprocket
Old Jan 29, 2008 | 06:47 AM
Alpar's Avatar
Alpar is on a distinguished road
new sprocket
I currently have 43 tooth rear sprocket on my superhawk from the previous owner. I assume the front one was left at the stock 16T.
I wan't want to go to a 15T in the front and up a couple of teeth in the rear. I just wanted to know if any one of you guys has tried that or is running 15/45.... any thought or comments would be appretiated before i buy the new sprockets.
Thanks.
Old Jan 29, 2008 | 08:16 AM
gssbmm's Avatar
gssbmm
I run a 15/45 on the track. I would not suggest it for the street. the rpm on the freeway is around 6500/7000 crusing at 65. personaly a 15/43 is more then enough and a big differce. I went the same route with at 530 16/41 to a 16/43. and then did a 15/45 when it became a 90/10 track/street bike. I also keep a 43 sproket for longer tracks. a 15/45 is really short gearing much shorter then you would think.
Old Jan 29, 2008 | 08:34 PM
Alpar's Avatar
Thanks for the input... that helps a lot to decide which one to go with
Old Jan 30, 2008 | 08:50 AM
434josh's Avatar
434josh is on a distinguished road
I haven't pulled off the cover to see the counter shaft sprocket, but my rear is a 43. Mine was bought used and modded as well. I run about 4500-4800 rpm on the highway.....70ish since speedo is way off. Reads about 90 while running with traffic.
Old Jan 30, 2008 | 10:21 AM
FL02SupaHawk996's Avatar
Fastest Color
+1 on the 15/43 and you can use stock chain too...
Old Feb 4, 2008 | 10:56 AM
98honda's Avatar
98honda is on a distinguished road
not sure what the front is on mine, but the rear is 43, and my speedo is off pretty bad, if im at 90-95 or so, im doing 80-85 and only turning about 5000-5500 rpm
Old Feb 4, 2008 | 10:57 AM
98honda's Avatar
oh and it is easy to do a second gear wheelie from 40-45 all the way to third gear.
at the track i hit 100 mph in the 1/8 mile, and thats the top end third at 9600 rpm.
Old Feb 4, 2008 | 11:01 AM
Fastest Color
98honda: I'd guess your front is 15 and I'd suggest using a speedo healer to correct your readings and avoid phantom miles...
Old Feb 4, 2008 | 01:11 PM
Hotbrakes's Avatar
I'm running the 15/43 520 kit. 5th gear standups aren't a problem with a good yank on the bars.
Old Feb 5, 2008 | 03:17 AM
98honda's Avatar
realy, thats sweet^^ how fast are you going when you pull it up? i never tried to do the stand up wheelie, to scared
i set forward to the tank when i 1st gear, and then roll into the throttle, powers on up but in 2nd i'll sit in the seat, hit about 40 is were i like it, and pop the clutch and up she comes and i try to just keep it up as long as i can till i shift to 3rd, and then it comes back down.
were do i get speedo healer at?
Old Feb 5, 2008 | 08:07 PM
Hotbrakes's Avatar
I used to only do sit downs myself. Then my friend kept telling me to stand up. So I did, and from then on I was a pro. Much more control and I don't have to keep accelerating cause I'm at balance point. I switched to the 15/43 and now I can come out of turns on the back wheel no problem. It's also a good idea to cover the back brake as well.
Old Feb 6, 2008 | 09:58 AM
98honda's Avatar
what do you do, to do a stand up wheelie?
just stand up, pull up, and then throttle at the same time?
Old Mar 4, 2008 | 04:36 PM
02MONSTERHAWK's Avatar
02MONSTERHAWK
Thumbs up Speedo Healer
Goto www.tobefast.com good price and fast shipping.
t-dogg
May 23, 2009 09:18 AM
Rollin20z
Dec 29, 2008 08:18 AM
duran
Aug 27, 2007 07:57 AM
duran
Jun 4, 2007 10:38 AM
Speed_Demon
Dec 26, 2005 10:36 PM
