Idle hands.....
Old Jan 16, 2013 | 04:40 PM
Idle hands.....
you know the rest, lol
Presenting the inspiration for my latest project:
Not sure what you gents think but I love the tidy look of the rear brake master set-up on this bike. So, it being winter in Canada, and my brain being afflicted with OCMD, I am inspired to try something similar.
The MC on the picture comes from a Honda CRF motocross bike. Regrettably, it uses a small 3/8" piston (about 9.5mm), much too small for the VTR which uses a 14mm piston OEM. After doing some "rootin' around", I noticed that the similar Nissin units used on RM-Z and KX bikes use a significantly larger 1/2" piston (12.7mm), which is much closer size-wise to the VTR unit. In fact, I figure it's close enough to try a swap.
I picked one up cheap on eBay and will see if the mounting holes line up when it gets here (if not, it will be going back up for sale). If it does, I will replacing the banjo with a pressure switch unit to tidy up the wiring (as on the picture). I will also be looking for a "blingy" anodized cover (blue) to finish it off.
Will keep you posted
Old Jan 16, 2013 | 07:08 PM
You mean you don't like the high tech/low weight race look I've seen folks do and just chop the brake line a couple inches above the mc and jam a bolt in it? Seriously though that does look cool let us know if it works out.
Old Jan 16, 2013 | 07:33 PM
surely from the same crowd who stretch swingarms to no end, remove a rotor on the front (and, of course, have a plethora of spikes).....
Old Jan 16, 2013 | 08:50 PM
http://www.2wheelpros.com/brembo-rac...FQUFnQodFTIA2g
For those on a budget...I like your idea better.
Old Jan 17, 2013 | 05:48 AM
Jumping Jehosophat!!!!! Pretty expensive, especially considering it looks strikingly similar to the unit used on KTM dirt bikes (mind you, it is the "red label" edition, whihc means it is probably machined from billet or something of the sort).
Old Jan 17, 2013 | 06:02 AM
wolfgun's Avatar
wolfgun is on a distinguished road
Master Cylinder
Whatever you do, don't try to use this one!
Old Jan 17, 2013 | 06:12 AM
chemomche's Avatar
chemomche is on a distinguished road
Hm, not related, but why the hack is the brake fluid in this resevior blue???
btw, have you seen this
Old Jan 17, 2013 | 06:15 AM
Most likely they use DOT4, which is blue, but that is used more on Harley's and such
Old Jan 17, 2013 | 06:21 AM
chemomche's Avatar
I have never seen blue brake fluidI have used DOT 4, but it was the same colour(almost transparent) like the 5.1
Old Jan 17, 2013 | 06:51 AM
IIRC, I think the blue fluid is Motul (RF600?), the guys at Speedzilla rave about it
Old Jan 17, 2013 | 07:01 AM
Here is an MC like the one I bought:
http://www.ebay.com/itm/2005-2009-Su...0572e4&vxp=mtr
You will notice that the resvoir window is not on the back but on teh side (teh inside once mounted). This may complicate checking the fluid level slightly but, IMO, this minor inconvenience was worth it for getting a significantly larger piston than the Honda unit.
I may have to work at making an adaptor/bracket if the holes don`t line up but we`ll get to that in due course.....
Old Jan 17, 2013 | 09:35 AM
It's not RF600 (tried it but my SP2 system didn't like it for some reason and have gone back to "standard" fluid)
The only fluid I have seen that is blue is the silicone based DOT5 but who really knows.
Old Jan 17, 2013 | 09:46 AM
I stand corrected......
Old Jan 17, 2013 | 09:57 AM
No worries..... though make sure you check the thread pitch, as it might be different than Honda, so you get the right banjo bolt.
Old Jan 17, 2013 | 10:12 AM
Actually, a quick seach turned up the yz250f/450f rear master cylinder, which is 11 mm, and the exact same shape as the one in your original picture...
Hmm... Somehow I ended up buying one of the ones I found... Imagine that...
BTW, I blame you on this one... Whole heartedly...
Old Jan 17, 2013 | 10:28 AM
Thanks Markus, glad I could be a bad influence for you, lol
I too had checked the Yamaha MC before settling on the RM (same as KX) unit. I simply wantex to get as close to the OEM 14mm diameter as possible, and that was with the RM/KX unit. Truth be told, I was bummed that the Honda`s Nissin unit had such a small piston diameter as I really like the location of the fluid level window and would have loved fitting one of the snazzy red anodized HRC covers sold on eBay. Oh well, function before form.....
As far as banjo bolt threads are concerned, Brembo uses M10x1.0 while Nissin uses M10x1.25. As all Jap bikes come with Nissin, it`s a universal fit....
Old Jan 17, 2013 | 10:31 AM
Thanks Mike, I forgot to mention that is Silicone based and for what ever reason they use it allot on Harley D's, now I remember clearly
Old Jan 18, 2013 | 09:47 AM
Oh, not to worry... I'm bound to come up with a stupid idea sooner or later that will rub of on you... Us OCMD people likes having friends to influence, you know...
I figured that the difference between 11 mm and 14 mm piston size will be negible really in normal usage... And since it takes quite some effort to lock up the rear on the VTR with the stock mastercylinder, even if the smaller cylinder will increase pressure, and make it "easier" to lock up, it will probably require enough travel that you will figure out before hand that you are being silly... It might be a little less progressive than stock, but not that much really...
Old Oct 31, 2013 | 01:43 PM
steppenwolf's Avatar
Сила в правде
steppenwolf is on a distinguished road
Smile
undefined
Old Oct 31, 2013 | 01:53 PM
Сила в правде
Old Oct 31, 2013 | 06:32 PM
OhYouJest's Avatar
OhYouJest is on a distinguished road
^ That stuff makes a difference, had it in my gsx-r. Better feel for sure.
thedeatons
Jun 21, 2015 09:11 PM
gboezio
Sep 30, 2008 09:17 AM
SD Hawk
Jun 29, 2008 05:34 PM
996RIDER
Sep 21, 2007 11:15 AM
DaxMiddler
Apr 28, 2006 03:22 AM
