Hi-Mount Over-Hyped?
After reading lots of info here about exhaust, everyone seems to be saying install Hi-Mount Pipes Jardine, 2 Bros, etc. However, before doing so there seem to be many issues with this approach.
-Do you have to install a rear fender eliminator for Hi-Pipes to fit
-Do you lose your rear footpegs w/hi-pipes
-Lots of heat now located directly under your seat (is it hotter?)
-Will the extra heat melt or distort the plastic painted rear cowl
-Manufacturers today are moving their exhaust down low and smaller and you guys are saying move the mass up high
-NO rejetting needed with pipes only
-YES rejetting needed for pipes
I just want the bike to sound sweet and run normal, is that possible?
WHEW, lot's of FAQ's rolled into one!
Originally it was for cornering clearance. Swapping 7lbs up high for 25lbs down low is still a good thing (made up those figures but they're close). You can keep pass. pegs but a lot of folks replace or move the turnsignals. No real issues with heat (been around nearly as long as the bike). Most don't require jetting but encouraged it.
In the end, it's for looks. They just look a lot better IMO and lots of other folks' agree too. Very popular mod. ANY good pipe will let the bird sing a very sweet song. Money well spent. I had both high and low and the both sound suh-weeeeet.
Jardine provides spacers to extend the footpegs and clear the pipes. A few other manufacturers have similar solutions. In any case fabricating ur own spacers is not a big hassle.
A lower CG is preferable. But with low mounts u don't have enough clearance to lean the bike more than 70-80 degrees. Well , if u drive like Edwards, that can be an issue.
Seriously I think you're overreacting a little. The only issue is getting some smaller turn signals with most besides jardines...Most also come with longer bolts and spacers for the passenger pegs (and if they don't you can use a set from one of the manufacturers that does or make your own), and if mounted properly they won't come into contact with the fairing. I have leo's and I cut the under fender a little and bent the hangers in to get them as high and close as possible and if you're careful they still won't touch the fairing. Heat's not an issue either. And no offense to anyone on here but no one on here is a good enough rider that they need to worry about the "mass" of their high pipes slowing them down...if it could possibly do that anyway...oh and I've tried almost every exhaust they make at one point or another including headers and I've never had a jetting issue...
I got high mounts to help with ground clearance, but unfortunately (with the Leo Vince's) the mid pipes drag at full lean to the left in certain situations. But they certainly look badass! I had to change turn signals to a license plate mounted signal because there is no room for anything else. Passenger pegs are in use, in fact I had to use the passenger pegs with the particular bracket and spacers that were included. No heat issues. My heels do hit the mid pipes and the passenger peg brackets. This is useful to me at the track, but might be a problem if you had big feet or rear sets. All in all, I would not change back because they look way too bitchin'. (and that is the reality of the matter!)
i love my my black low mount d and ds. very loud, but still has a great tone. honestly didnt notice much performance, but i got to keep my back pegs and they run VERY cool. last summer my five year old niece got off the bike and set her hand on the pipe...everyone looked over and freaked out but she was fine.
they were also easy to install.
... And no offense to anyone on here but no one on here is a good enough rider that they need to worry about the "mass" of their high pipes slowing them down...
Um, yeah? That is why I had to do an undertail with integrated tailight. Everytime I leaned over i was dragging the side of the bike....especially when I lowsided. Now my mufflers never get damaged!
Here's a way to not scrape your low mounts in the corners.........hang off the bike!
I've had both didn't notice much difference in handling, burnt my boots though. I think it looks cleaner but I've gone with low mount pipes high mount hangers.
I love my Devil highmounts. They look great, I have my passenger pegs, and my turn signals are just relocatted aftermarket ones.
Plus they sound killer even though my camcorder doesn't replicate it too well. very thunderous and mean sounding http://smg.photobucket.com/albums/v1...devil_clip.flv
Better video http://smg.photobucket.com/albums/v1..._exhaust_2.flv
I just upgraded to Micron high mount slip on's, and I gotta say.. i decided on high mounts purely because I thought they looked awesome.. and the Micron's sound AWESOME...
i gotta take some pictures now that the bike is put back together with fairings again...
little squirt
Aug 16, 2009 02:47 PM
superhawk22
Apr 3, 2006 03:38 PM
