front sprocket change
Old Oct 31, 2004 | 09:12 PM
wheeliefun996's Avatar
wheeliefun996
Is there anything I have to do when changing the front sprocket because of the clutch? New gasket, or bleed it when I'm done? I've never had a hydro clutch before, just curious, any advice before I get it apart. Thanks, twins rule!
Old Nov 1, 2004 | 05:43 AM
Shmittay's Avatar
Shmittay
Re: front sprocket change
Nope. Changed mine a couple weeks ago. You will just need to adjust the chain as you will have a little more slack than before. Just make sure to tighten it to the correct specs. Enjoy the much harder pulls
Old Nov 1, 2004 | 11:24 PM
faz's Avatar
faz
faz
this is something that I need to do as well.
There isn't really much to it. If you look around on the web, you should find plenty of sites with explanation on how to do this, may be not on a VTR, but the idea is basically the same.
remember your speedometer is going to be showing higher speed and your miles are gonna go up as a result. but you will be enjoying more torque which is almost always welcome!
where did you buy your sprocket from, and how much??
Old Nov 2, 2004 | 07:37 AM
Shmittay's Avatar
Shmittay
I ordered my front from Motorcycle-Superstore.com. The AFAM 15T, for $29.99.
Old Nov 2, 2004 | 07:09 PM
wheeliefun996
Thanks for the input. I've changed lots of them on my previous bikes, I just was'nt sure with the clutch being there. I already have a 43t in the rear, which is great, now well see about some slower stuff?
Old Nov 3, 2004 | 12:13 AM
faz's Avatar
faz
faz
thanks for the info.
Old Jul 22, 2006 | 11:51 PM
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
does is really screw up your mileage??
Sherm831
May 18, 2010 07:07 PM
joshuatest
Apr 6, 2008 09:18 AM
NOrrTH
Nov 25, 2005 09:59 AM
sckomar
Aug 9, 2005 07:23 AM
102dals
Aug 7, 2005 08:50 AM
