Front and Rear Wheels
Old May 17, 2010 | 08:05 AM
Seattle_SuperHawk's Avatar
WWTDD
I see a lot post and mods that include a CBR wheel upgrade ??? i am a dumbass , so can someone please tell me what you gain from this Modification, I am always looking for good ideas and info.
Old May 17, 2010 | 08:12 AM
aesthetics, 6 spokes vs 3. A very slight gain in weight too. Now you know
Old May 17, 2010 | 08:33 AM
WWTDD
Well untill i post the next dumbass question, Thank You...
Old May 18, 2010 | 08:24 AM
slo1's Avatar
slo1 is on a distinguished road
Coolness
Old Jun 3, 2010 | 01:31 PM
Raisidlo77's Avatar
Raisidlo77 is on a distinguished road
Please, what year it must be CBR RR? I just know that it must be 900 RR. Thanks
Old Jun 3, 2010 | 02:01 PM
Well since the CBR 900RR was made in 93-95 I'd say it's likely those years... 96-99 it was officially named CBR 919RR and then in 00-01 CBR 929RR, 02-03 CBR954RR... Dunno for sure either way but the 919RR and the 900RR might be the same?
Keep in mind though that the front needs to be an CBR 600F3...
Old Jun 4, 2010 | 05:23 PM
I think a rear wheel from a 900RR/Fireblade up to and including 99 will do....
Old Jul 18, 2010 | 07:14 AM
georgedombeck's Avatar
georgedombeck is on a distinguished road
Why wont an f2/f3 rear wheel work?
Old Jul 18, 2010 | 07:54 AM
Can't say for sure since I haven't researched it, but either it's untested, as in might work, but you get to try it out...
Or some of the dimensions like axle size or width at the axle or sprocket carrier or... makes it not fit...
Or it's visually not the same?
Old Jul 18, 2010 | 08:10 AM
slo1's Avatar
If you want to run a "little" tire it might. f2/f3 came with 160 rear tires (4.5" wheel?) till 97-98 when they went 180.
Maybe the 97 & 98 f3 would work.
Old Jul 18, 2010 | 11:46 AM
I am going to try it, I have a F3 rear it measures 5.5" will a half an inch make that much difference? g
Old Jul 18, 2010 | 11:59 AM
slo1's Avatar
5.5" is what you want, as that is the size of the stockers, and the 900rr rears. looking forward to your results.
Old Jul 18, 2010 | 12:10 PM
Well I hope it wont be too hard. I have done cbr f3/f3 wheel swaps onto the old 1986 vfr. Had to make spacers , but after that it worked ok. g
Old Jun 3, 2012 | 02:02 AM
Tebs's Avatar
Tebs is on a distinguished road
Okay Squid needs assitance with wheel interchange...
I read "The Guide" on the front fork swap, and I have searched diligantly for "wheel swap" "front wheel modification" "front wheel swap" yada yada yada, is there a "Wheel interchange guide" listed on this forum? Pardon my ignorance if I missed it i'm new. Thats my excuse and I'm sticking to it. I found this link....
https://www.superhawkforum.com/forum...-wheels-22546/ my question is are there anymore options out there besides these?
Old Jun 3, 2012 | 05:50 AM
No, not really... Those wheels mentioned here are the one's that essentially just bolt on... Then there are aftermarket wheels which are becoming increasingly rare/expensive, and then you need to swap fork/swingarm to make other wheels fit...
Old Jun 3, 2012 | 08:33 AM
Tebs's Avatar
Cool thanks for the help! (Just not a big fan of the 3 spoke SH wheels).
Old Jun 5, 2012 | 05:20 PM
seb421's Avatar
ukbiker.me
seb421 is on a distinguished road
This tells you all you need to know and why you should by light wheels
Effects of Inerita
its all about inertia
hope that answers your questions
Old Jun 5, 2012 | 10:03 PM
The wheels swap works well up to 2011 CBR1000RR, along with the fork swap from 2006-2007 forks!
The only thing you got to remember is the size of rotors to match the caliper position depending on the year.
As for the rear wheel, it does work as well and you loose whole 5 pound compare to the stock wheel and gain half inch width in the same time, there are few more details and tricks to the rear wheel installation for this late model 2008-2011 CBR, but they all relatively easy.
dallard2
Dec 29, 2014 05:54 PM
red_rocket98
Jan 10, 2011 06:31 PM
t-dogg
Oct 6, 2010 05:04 PM
iamanonymous
May 30, 2007 12:13 PM
trinity012
Nov 11, 2006 06:31 PM
