Fork oil height with Racetech springs
Old Mar 14, 2010 | 10:35 AM
residentg's Avatar
I am installing Racetech .90 springs in my stock forks. I have them all apart and cleaned up. My question is, given that the Racetech springs have a larger volume (they take up more room), than the stock springs, how will that affect fork oil level measurement? Since oil level is measured before installing the spring, the level should be lower than the stock spec of 130mm, but by how much?
I saw a recommendation on another post from 2004 that suggested 155mm, any comments on that?
https://www.superhawkforum.com/forum...fork+oil+level
Originally Posted by Random
Here's what racetech used for my setup.
Type 1 Gold Valves
.95kg/mm springs 20mm preload
Oil ultra slick US "2"
Oil Level 155mm
Compression valving cH 36
Rebound Valving rH R-19A
Compression adjuster - out
Rebound adjuster 1 1/2 out
Somma that stuff only RaceTech guys understand. "as delivered" from race-tech, it was WAY too soft. (adjusters were all turned out). It's taken me about 500 miles of commuting/canyon riding to get it where I like it.
I suppose that I could OCD this by measureing fluid displacement in a pan of water with the different springs placed into it, but my shrink would object, I am sure.
Thank you.
JB
Old Mar 14, 2010 | 11:03 AM
That may be a bit too low. I think I'm running about 5.75" (146mm) or so but I'm 215+
Old Mar 15, 2010 | 07:37 PM
RichDesmond's Avatar
RichDesmond is on a distinguished road
Thank you.
JB
Anywhere in the 135-140mm range is fine. Just make sure both sides are the same.
Old Mar 16, 2010 | 01:11 PM
RCVTR's Avatar
It's more a matter of the air volume, than the total oil volume.
I would start at the recommended oil height - regardless of spring. There wil be very little difference in displacement from the spring. It is not completely submerged.
You can then fine tune the ramp rate of the fork from there, by increasing/decreasing the air volume with oil height adjustment. Or leave it where it is and ride it!
Old Mar 16, 2010 | 05:12 PM
JamieDaugherty's Avatar
When assembling VTR forks I will normally run a fluid level of 120mm. A lower level can also be ok, but I've found the extra fluid helps with bottoming.
Old Mar 16, 2010 | 05:37 PM
trinc's Avatar
from a write-up between a guy in japan & UK racing they found that with stock valves 140mm air gap using 7w oil was a good setup.
they also step through grinding off the step on the rebound needle but i didn't want to go down that road.
http://www.ablett.jp/bikes/vtr/vtr_sus.htm
tim
Old Mar 16, 2010 | 06:11 PM
Hopey's Avatar
Hopey is on a distinguished road
Thumbs up Your Neighbour!
I sent mine to Greg Nemish,he's in New York State. He worked his magic on them and there is a huge difference!I would give him a shout!
Old Mar 16, 2010 | 08:28 PM
residentg's Avatar
I intend to do that at some point, that is whay I am only replacing the the weak stock springs for the Racetech, and not doing any other mods.
I cleaned everything and replaced the seals, the bushings still show 100% teflon. I ending up using 7wt Belray with 135mm height. The spacers I cut to 72mm, that gives me 15mm preload at the softest preload setting (the adjuster all the way out) which is what Racetech recommends for spacer length. After I ride it a bit, I may adjust some of this. When I have more cash, I'll get the forks rebuilt. Thanks for all your help everyone. JB
Old Mar 17, 2010 | 02:02 PM
Hawkagain's Avatar
Hawkagain is on a distinguished road
[quote=residentg;257607]I am installing Racetech .90 springs in my stock forks. I have them all apart and cleaned up. My question is, given that the Racetech springs have a larger volume (they take up more room), than the stock springs, how will that affect fork oil level measurement?
Just a small maybe not that helpful comment but I would expect that the Racetech springs have a lower volume. Stiffer springs have fewer coils that are spread further apart. I also agree that the volume difference in the springs is insignificant to the total volume inside the forks.
Old Mar 17, 2010 | 03:50 PM
residentg's Avatar
I had the springs side-by-side last night, now that you mention it, that was the case. Thank you. JB
AngryOlaf
May 25, 2010 09:39 AM
tfsttr
Apr 10, 2010 07:27 AM
Hawkrider
Jul 4, 2009 08:36 PM
Sablotny
Sep 1, 2008 04:25 PM
CNI Dawg
Jun 6, 2006 07:23 PM
